Dale7905
#1 Posted : Tuesday, March 16, 2010 7:33:00 AM(UTC)
Dale7905
Hello,
The tub is not spinning for the spin cycle. The center post and agitator are spinning at high speed during the spin cycle, but the tub is not. The water was all pumped out of the tub, but the tub did not spin while the water was being pumped out.
Thanks for any comments,
Dale7905
sidfink43
#2 Posted : Wednesday, March 17, 2010 10:20:44 AM(UTC)
sidfink43
The two likely suspects are the clutch and the drive block.
I would start with the clutch, and if that checks out, check out the drive block.
Dale7905
#3 Posted : Wednesday, March 17, 2010 1:49:01 PM(UTC)
Dale7905
Thanks for the suggestions. I checked the tub and it rotated freely so I removed the agitotor top and discovered the tub drive block tabs had been sheared off. I replaced the drive and it looks like that solved the problem. Many thanks.
Dale Houser
sidfink43
#4 Posted : Wednesday, March 17, 2010 2:46:03 PM(UTC)
sidfink43
Great, glad you got it fixed and thanks for the update.
