I have a Maytag LAT9304AAE that is completely dead, as if it is getting no power. I have replaced the cherry switch and fuse with no effect. Where is the next place to look? I am stumped.
I assume that what is happening is that the water valves will not open to start the washing process.Check to see that current is flowing into the timer and that you are not getting power to the water valves at start up. If so, the timer probably has some type of internal short and is not sending out power.
Thank you for the tip. I have 2 working units I can swap parts from to test the theory this weekend.
