my washer went through the wash,rinse,and most of the spin cycle.It then started to vibrateand make a loud rubbing noise.Ther was about 1" of water left in the tub.When I rotated the cycle switch to spin it makes that rubbing noise.What could cause this?
It can be the pump bearing starting to fail; or it could be the thrust bearing, not allowing a full release of the brake. Pull the belt off and see if you get that sound as you spin the pump pulley by hand.
Good Morning, Thank you .I will try that
