campereve@hotmail.com
#1 Posted : Monday, March 15, 2010 12:37:24 PM(UTC)
washer stopped working - nothing happened when knob was pulled. Replaced switch - worked long enough to fill with water and then stopped. Was told it may be timer and to test with voltage meter - can you give help for this? Wiring diagram and testing for what?
#2 Posted : Monday, March 15, 2010 2:44:05 PM(UTC)
The first thing I would do is remove the access panel and the control panel and check all harness plugs and connectors, especially where it goes down through the washer top panel.
Which switch did you replace?
Here are the breakdown diagrams and Replacement parts for MAYTAG LSE7804ACE Stacked Laundry - Ele | AppliancePartsPros.com
Scroll the diagrams list all the way down to see the wiring diagrams.
Instructions on replacing timer (Washer Repair)
by SEPAZ 5/30/2015 11:37:34 AM(UTC)
Replacing Timer but can't find a replacement (Washer Repair)
by 1SpackerS 4/5/2015 6:23:56 AM(UTC)
Replacing Timer Switch-uh oh-Wrong timer sent? (Dryer Repair)
by travisp83 3/16/2015 1:06:43 PM(UTC)
replacing timer in washer dryer combo (Washer Repair)
by newlyretired 1/15/2012 9:30:36 AM(UTC)
Replacing timer on MayTag Dryer (Dryer Repair)
by gpatterson 3/30/2011 3:40:54 PM(UTC)
replacing timer on clothes dryer (Dryer Repair)
by Al43110 8/8/2010 12:42:00 PM(UTC)
maytag stopped running and won't start back after replacing timer (Dryer Repair)
by draroberts 6/15/2010 4:37:32 AM(UTC)
Replacing Timer on Maytag Washer (Washer Repair)
by mrccg 4/14/2010 9:43:54 AM(UTC)
Replacing timer assembly and lid switch (Washer Repair)
by JTScarbrough 2/5/2010 10:29:00 AM(UTC)
Replacing Timer (Washer Repair)
by Dobermann 11/4/2008 8:43:38 PM(UTC)
