hi,
is the drain pump in this washer pretty standard, the one thats in it has a metal plate that it mounts to then the basepan in the washer,
but the one i see on here doesnt.
one site says there is about 10 different pumps that will work just fine.
says 21002240 and 35-6780 and some other part numbers are the same pump with the same mounting specs and will finction fine.and that with or without the plate is ok too.
sound correct?
