The drum is turning but not fast enough on the spin cycle. When the rotation stops, the clothes are still soggy at the end of the cycle.
Remove the rear access panel. Remove the belt and check how freely the inner drum is moving by rotating the main pulley in both directions. Inspect the belt. If there is nothing wrong, replace the motor speed control board (#4 on the diagram). - The belt Part number: AP2108082
