Hi there,
wondered if anyone can help me. i am trying to remove the inner tub assembly from my stackable washer/dryer unit and not sure how to do it. I removed the agitator ok but not sure how the inner tub comes off. I am trying to get the washer apart because I would like to inspect the bearing assembly etc on the bottom end of the tub. I was starting to get noises on the spin cycle and banging also so thought i would pull it apart to see if anything was worn.
Does this make sense? any help would be appreciated. thank-you. Malcolm
