Discuss
Front Door Boot Gasket - GE
 in
Washer Repair
Hello everyone, I'm new to the forum and share the same problem. My ge model uses this same gasket. My
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Front Door Boot Gasket - GE
  #51 (permalink)
Old 11-18-2010, 08:08 PM
Junior Member
JayCue is on a distinguished road
Default
Hello everyone,
I'm new to the forum and share the same problem. My ge model uses this same gasket. My mother noticed some water on the floor so I investigated. It had been dripping for a while by the looks of all the rust.
The boot gasket doesn't appear to have any rips/tears. The drain holes at the bottom of the gasket had lint and other debris in them. I removed the gasket to clean it all out. There was also a little lint in the holes of the tub that the gasket connects to. Cleaned all that.
Here's my question. Since I can't find a rip in the gasket, is it possible for water to leak out if the drain holes are clogged? I'm thinking the outer clamp wasn't tight enough perhaps? The water leak was at the center of the machine. The water would dribble down the concrete piece below the gasket and behind the lower trim panel, rusting all the metal.
Can I reuse that gasket?
Ads By Google
  #52 (permalink)
Old 01-25-2011, 03:54 PM
Junior Member
jasonmc is on a distinguished road
Default
I totally agree with ksisco.. I just dismantled my machine in the garage and after looking at it, i will save myself some pain by removing the front and also maybe the concrete counter-weight... I am ordering my boot and will be installing it soon.
  #53 (permalink)
Old 01-25-2011, 07:17 PM
Junior Member
Default
I actually reused my gasket because it wasn't the problem. After further inspection, I discovered the water inlet pipe had a crack in the bottom of it, where it connects to the soap dispenser. With the boot still off, I plugged the other end of the pipe with a bag and rubberband. Poured a little water in and it dripped out the crack, ran along the counterweight and onto the lower panel.
Ordered a new pipe and seal, sanded the rust spots away and painted the bare metal. Reassembled and it's ready to go. The water inlet pipe was backordered for a while. I wonder if this happens a lot?
Thanks to the forum for the descriptive instructions. And it's a lot faster to remove the counterweight. Just have pieces of tape for the nuts when you re-assemble.
  #54 (permalink)
Old 08-31-2011, 11:55 AM
Junior Member
luked is on a distinguished road
Default
This repair is easy, if a bit annoying. It took me about 1.5 hours. Taking everything apart was simple. Installing the boot itself had 3 annoying steps figuring out how to get the boot onto the drum, figuring out how to get the little spray thing into the hole, and stretching the spring-loaded clamp onto the boot.
Anyone with a bit of strength, a rudimentary mechanical sense, and the right tools, can do this without any problem. I removed the lower concrete counterbalance for access to the inner clamp.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Rubber gasket on Front Load Washer door pbraley Washer Repair 1 07-26-2009 04:53 PM
help on installing door gasket to drum on front load washer df134 Washer Repair 1 02-06-2009 08:04 PM
door seal +boot +gasket install misterfixall Washer Repair 0 10-30-2008 12:29 PM
how to install door boot on front load washer suzette Washer Repair 1 09-11-2008 10:23 AM
water leaks front door needs gasket? chiko Dishwasher Repair 0 01-25-2008 11:56 AM
