| » Front Door Boot Gasket - GE |
Sure, open the door, and on the bottom of the boot, lift up on the rubber to expose the outer ring that holds it to the front. Grab the ring by the spring with some needlenose pliers and pull it off.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
Great post, thanks for the detailed instructions!
When I ordered the door gasket from a local parts shop, their system pulled up the part number WH08X10036 would fit my model washer. My first time to replace the boot, so it took at least 4-5 hrs. Most of the time was trying to get to the screw on the inner ring. I tried the suggestion of using needle nose pliers and 1/4 drill extension with 1/4 phillips head, but I couldn't get a good angle with my model washer. I think part of the suspension mechanism was in the way. Went to Lowes and found a GearWrench MicroDriver. Spent a while trying different positions and extensions until I was able to get something that worked. Removing the lower access panel lets you have one arm from underneath to work the wrench, and the other arm from the front to keep pressure on the screw. It was slow and frustrating because of the limited space, but eventually the screw is loose enough that you can turn it with your fingers, and get the boot off. I also spent a lot of time using the old damaged boot to do some "practice runs" of re-seating and lining up the gasket. The part seems pretty durable, but I was paranoid about ripping the new one by accident. Thanks again for this post, it was a life saver! |
i do not have my washing machine model number with me; however i do know that the part number for the boot is WH08X10036. Where can I find detailed instructions for replacing this part? Are there schematics available? Thanks so much.
In order to provide most accurate advise we need the complete model number of the washer.
__________________
Professional appliance repair in Orange County, California. |
After reading the posts about the common man replacing the gasket I felt I could do it. After removing the old and about 20 min into putting in the old, I gave up. I dont know how you can get that gasket on with the front of the machine on, so I took the entire front of my machine off as well as the top. It took about 5 min and Within 10 min I had the gasket on with the help of my wife's hands to hold the top portion after I got it started. **NOTE: when you take your control panel off and unplug the 9 number plugs, number them so there is no mistake to where they go when its time to reinstall it. Then I put the front and top back on and the front portion of the gasket was pretty easy too. Dont pay $125 + for someone to replace this.
Quote:
I dont remember if it was on the drum or not but with the help from my wife she held the top and I stretched the gasket around the lip. It was a bit tight. I think I know what other lip your talking about and if u look at the lower part where there are slots for the water to drain you can see that the gasket needs to go to the lower lip so water doesnt drain onto the floor but rather into where it is suppesed to go. I have no idea how anyone can put this on without taking off the from of the washer. With my wife's help I got this on in about 20 min with very little frushration. Also this was our first time doing this repair.
ks |
| Display Modes | |
| oven door gasket | jweikerth@comcast.net | Oven Repair (including Ranges and Cooktops) | 0 | 05-02-2008 01:23 PM |
| door gasket installation | ghw51 | Refrigerator & Freezer Repair | 1 | 04-30-2008 03:05 PM |
| water leaks front door needs gasket? | chiko | Dishwasher Repair | 0 | 01-25-2008 12:56 PM |
| How Do I Replace Door Gasket? | stevekfall | Oven Repair (including Ranges and Cooktops) | 4 | 01-20-2008 01:03 PM |
| Door gasket | gla80 | Refrigerator & Freezer Repair | 0 | 10-18-2007 05:58 AM |
