My knob on the washer pulled off. I ordered the replacement but i'm not sure how the timer comes apart to replace the part.
Looks like the knob just screws on. You usually can just push in the knob, or shaft to select a cycle, then just screw the new one in.
Originally Posted by: richappy Looks like the knob just screws on. You usually can just push in the knob, or shaft to select a cycle, then just screw the new one in. It worked just as easy as you sugested, Thanks
It worked just as easy as you sugested, thanks.
