Discuss
Front Loader Balance problem
 in
Washer Repair
My Kenmore front loader (mdl 417.40042990) goes off balance on the high spin cycle.It is bouncy on the regular spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Front Loader Balance problem
  #1 (permalink)
Old 08-30-2007, 07:35 PM
Junior Member
bersie is on a distinguished road
Default Front Loader Balance problem
Model Number: 417.40042990   Brand: Kenmore   Age: 5 - 10 years
My Kenmore front loader (mdl 417.40042990) goes off balance on the high spin cycle.It is bouncy on the regular spin cycle but high speed ,it is just about bouncing off the side walls and front to back and a thumping noise that i can not find. I have had the shock absorbers (2) and the top springs (2) replaced,but NO success. Also,when we leave the machine for a couple of days it gets a mold smell even with the door open.Any help on either problem?
Thanks.
Ads By Google
Related Models
Kenmore 417.40042990  WASHER
Kenmore 417.40052990  WASHER
Kenmore 417.40142000  WASHER
Kenmore 417.41042000  WASHER
Kenmore 417.41052000  FRONTLOAD WASHER
Kenmore 417.41142000  RESIDENTIAL WASHER
Kenmore 417.42042100  WASHER
Kenmore 417.42052100  WASHER
Kenmore 417.42142100  WASHER
Kenmore 417.43042200  SEARS/FRONTLOAD WASHER
Kenmore 417.43052200  SEARS/FRONTLOAD WASHER
Kenmore 417.43142200  SEARS/FRONTLOAD WASHER
Kenmore 417.59012890  GAS DRYER
Kenmore 417.69042990  KENMORE DRYER
Kenmore 417.69042991  DRYER
Kenmore 417.69052990  DRYER
Kenmore 417.69052991  ELECTRIC DRYER
Kenmore 417.79042990  DRYER
Kenmore 417.79042991  DRYER
Kenmore 417.79052990  DRYER
Kenmore 417.79052991  DRYER
Kenmore 417.80032990  DRYER
Kenmore 417.80042990  DRYER
Kenmore 417.80042991  DRYER
Kenmore 417.80052990  DRYER
Kenmore 417.80052991  DRYER
Kenmore 417.80142000  DRYER
Kenmore 417.81042000  DRYER
Kenmore 417.81042001  DRYER
Kenmore 417.81052000  ELECTRIC DRYER
Kenmore 417.81052001  DRYER
Kenmore 417.81142000  DRYER
Kenmore 417.81142001  DRYER
Kenmore 417.82042100  DRYER
Kenmore 417.82042101  DRYER
Kenmore 417.82042102  SEARS/DRYER
Kenmore 417.82052100  DRYER
Kenmore 417.82052101  DRYER
Kenmore 417.82052102  DRYER
Kenmore 417.82052103  SEARS/ELECTRIC DRYER
Kenmore 417.82142100  DRYER
Kenmore 417.82142101  DRYER
Kenmore 417.82142102  SEARS/ELECTRIC DRYER
Kenmore 417.83042200  SEARS/DRYER
Kenmore 417.83042201  SEARS/ELECTRIC DRYER
Kenmore 417.83052200  SEARS/DRYER
Kenmore 417.83052201  SEARS/DRYER
Kenmore 417.83142200  SEARS/DRYER
Kenmore 417.83142201  SEARS/ELECTRIC DRYER
Kenmore 417.88988100  ELECTRIC DRYER
Kenmore 417.88988800  ELECTRIC DRYER
Kenmore 417.88989100  GAS DRYER
Kenmore 417.88989800  GAS DRYER
Kenmore 417.89090100  WASHER DRYER COMBINATION
Kenmore 417.89090110  COMBINATION WASHER-DRYER
Kenmore 417.89090200  WASHER DRYER COMBINATION
Kenmore 417.89090210  COMBINATION WASHER-DRYER
Kenmore 417.89090400  WASHER DRYER COMBINATION
Kenmore 417.89090410  COMBINATION WASHER-DRYER
Kenmore 417.89090600  WASHER DRYER COMBINATION
Kenmore 417.89090610  COMBINATION WASHER-DRYER
Kenmore 417.89090800  WASHER DRYER COMBINATION
Kenmore 417.89090810  COMBINATION WASHER-DRYER
Kenmore 417.90032990  DRYER
Kenmore 417.90042990  DRYER
Kenmore 417.90042991  DRYER
Kenmore 417.90052990  DRYER
Kenmore 417.90052991  DRYER
Kenmore 417.90142000  DRYER
Kenmore 417.90802990  LAUNDRY CENTER
Kenmore 417.90802991  LAUNDRY CENTER
Kenmore 417.90802992  LAUNDRY CENTER
Kenmore 417.90807990  LAUNDRY CENTER
Kenmore 417.90812990  LAUNDRY CENTER
Kenmore 417.90812991  LAUNDRY CENTER
Kenmore 417.90812992  LAUNDRY CENTER
Kenmore 417.90814000  LAUNDRY CENTER
Kenmore 417.90814001  LAUNDRY CENTER
Kenmore 417.90814002  LAUNDRY CENTER
Kenmore 417.90817990  LAUNDRY CENTER
Kenmore 417.90862990  LAUNDRY CENTER
Kenmore 417.90862991  LAUNDRY CENTER
Kenmore 417.90862992  LAUNDRY CENTER
Kenmore 417.90872990  LAUNDRY CENTER
Kenmore 417.90872991  LAUNDRY CENTER
Kenmore 417.90872992  LAUNDRY CENTER
Kenmore 417.91042000  DRYER
Kenmore 417.91042001  DRYER
Kenmore 417.91052000  GAS DRYER
Kenmore 417.91052001  DRYER
Kenmore 417.91142000  DRYER
Kenmore 417.91142001  DRYER
Kenmore 417.91702000  LAUNDRY CENTER
Kenmore 417.91702001  LAUNDRY CENTER
Kenmore 417.92042100  DRYER
Kenmore 417.92042101  DRYER
Kenmore 417.92042102  SEARS/GAS DRYER
Kenmore 417.92052101  DRYER
Kenmore 417.92052102  DRYER
Kenmore 417.92052103  SEARS/GAS DRYER
Kenmore 417.92142100  DRYER
Kenmore 417.92142101  DRYER
Kenmore 417.92142102  SEARS/GAS DRYER
Kenmore 417.92702200  LAUNDRY CENTER
Kenmore 417.93042200  SEARS/DRYER
Kenmore 417.93042201  SEARS/DRYER
Kenmore 417.93052200  SEARS/DRYER
Kenmore 417.93052201  SEARS/DRYER
Kenmore 417.93142200  SEARS/DRYER
Kenmore 417.93142201  SEARS/DRYER
Kenmore 417.93702200  LAUNDRY CENTER
Kenmore 417.93802200  LAUNDRY CENTER
Frigidaire 41739012890 Frg(v0) / Washer
Frigidaire 41739012891
Frigidaire 41739022890 Frg(v0) / Washer
Frigidaire 41739022891 Frg/washer
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
  #2 (permalink)
Old 09-02-2007, 05:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi bersie
Most likely the problem with your washer is a worn out rear bearing. It's not available separate and comes as a rear shell assembly.
Open the door and try to move the inner basket up and down, and from side to side. If it moves a lot no doubts the problem is the rear bearing.
- The part number for the new rear shell (outer tub) assembly AP2578105
Good luck.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-18-2007, 03:07 PM
Junior Member
JEFFREYROBERT is on a distinguished road
Default
Its Very Possible The Drum Braket Is Broke Insead Which Should Be Under Warrenty.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag front loader problem sal.glenn Washer Repair 5 04-11-2010 08:05 PM
kenmore front loader fell onto front while moving. ohhhden Washer Repair 1 01-26-2010 07:22 PM
Knocking Noise Appears off balance Front loader NERAKNERAK Washer Repair 1 01-16-2010 08:46 AM
Frigidaire Front Loader Problem jmontgom Washer Repair 6 10-22-2009 05:45 PM
problem with loose drum inside front loader Big G Washer Repair 1 12-18-2007 03:04 PM
