Kenmore front-load washer will not drain. Cleaned out the pump (found a quarter, two nickels, what looks like a screwdriver bit and a little nail) and that is the second time in about three weeks I've done that. First time it was a paperclip, but stuff from today may have also been in there. I did a more thorough job and found most of the stuff in the hose that attaches to the pump. Regardless, after the first cleaning job, it was working fine. Now it won't drain. It does spin, just no output. Could it be the pump is burned out? Didn't notice any other blockages in the outlet hose, but suppose that might also be a possibility? Any ideas welcome.
I would pull the pump completely out, and check the impeller, probably broken. You will need the model# to order.
