Discuss
Washer just hums
 in
Washer Repair
I have a top loading maytag washer. It filled up with water but now just hums. Won't wash,drain.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer just hums
  #1 (permalink)
Old 05-27-2008, 08:23 AM
moon moon is offline
Junior Member
moon is on a distinguished road
Default Washer just hums
Brand: Maytag   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-27-2008, 08:27 AM
WasherGuy WasherGuy is offline
Junior Member
WasherGuy is on a distinguished road
Cool
What is the model # ?
  #3 (permalink)
Old 05-27-2008, 08:37 AM
Junior Member
Default
I have never been able to find the model number.I bought it about 6 years ago(new) it was mid range price. I had to replace the timer when it was
less than a year old...thats when we found out there was NO model number!
  #4 (permalink)
Old 05-27-2008, 08:28 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check the top of the control panel.
__________________
Professional appliance repair in Los Angeles, California.
  #5 (permalink)
Old 05-28-2008, 11:03 AM
Junior Member
Default
Sounds like a motor or a motor start switch. However, without the Model # it is hard to tell. Maytag sometimes put the ID plate on the upper back, left hand side of the control panel, look there.
  #6 (permalink)
Old 05-28-2008, 12:58 PM
Junior Member
Default
ok I looked on the control panel again the model number is not there.
I turned it on again and it hums at the fill....i turned it to drain and it does but with a horribly loud noise.Is there a belt to replace?
  #7 (permalink)
Old 05-28-2008, 01:00 PM
Junior Member
Default
If it is a motor is it worth replacing on a machine about 6 yrs old or
is it better to buy a new machine...any thoughts?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer stops and hums, after cooldown starts again gmboetr Washer Repair 1 05-15-2008 07:42 PM
kitchen aid superba washer hums loudly and will not spin mastertech Washer Repair 12 03-21-2008 05:29 PM
Hums... A New motor handiman43 Washer Repair 0 02-13-2008 01:36 PM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
Maytag Washer just hums spurzem Washer Repair 0 08-22-2007 11:17 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
