Discuss
Whirpool washer won't run
 in
Washer Repair
Washer was running but when wash cycle was complete would not pump out water nor agitate. There seems to be
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirpool washer won't run
  #1 (permalink)
Old 05-26-2008, 04:20 PM
Junior Member
asdf1855 is on a distinguished road
Default Whirpool washer won't run
Model Number: la9500xtw1   Brand: Whirlpool   Age: More than 10 years
Washer was running but when wash cycle was complete would not pump out water nor agitate. There seems to be a loud humming when it should be working.
I just replaced the water inlet valves and was working fine. However, we did hear a 'new' whinning when it was in the high spin cycle.
I have check the lid switch with an ohm meter. I opened the control panel and disconnected the lip switch connector. It seems to be operating correctly. zero ohms when closed and infinite when open.
I pulled the pump. It turns freely. I pulled the motor and inspected the coupler. The rubber coupling shows wear but is still in one piece. All three prongs look good on both ends. I turned the prongs going into the trans and everything seems to move smoothly.
I turned the motor shaft manually. When I reverse directions there is a loud click from the shaft bearings. I think it's too loud.
Is there anyway i can safely bench test the motor? Maybe it's just the starter capacitor? While waiting for a reply I'm going to remove the bear cap on the motor shaft to see if any bearings fall out.
What a way to spend a Memorial Day weekend.
Bill
Ads By Google
Related Models
Whirlpool LA9500XTW1
Whirlpool LA9580XWF0
Whirlpool LA9580XWF1
Whirlpool LA9580XWG0
Whirlpool LA9580XWG1
Whirlpool LA9580XWM0
Whirlpool LA9580XWM1
Whirlpool LA9580XWN0
Whirlpool LA9580XWN1
Whirlpool LA9580XWW0
Whirlpool LA9580XWW1
Maytag LA9600 Washer - Top Loading
Whirlpool LA9680XWF0
Whirlpool LA9680XWF1
Whirlpool LA9680XWG0
Whirlpool LA9680XWG1
Whirlpool LA9680XWM0
Whirlpool LA9680XWM1
Whirlpool LA9680XWN0
Whirlpool LA9680XWN1
Whirlpool LA9680XWW0
Whirlpool LA9680XWW1
Maytag LA9700 Washer - Top Loading
Maytag LA9700D Washer - Top Loading
Maytag LA9700S Washer - Top Loading
Maytag LA9700W Washer - Top Loading
Maytag LA9800 Washer - Top Loading
Whirlpool LA9800XKW0
Whirlpool LA9800XKW1
Whirlpool LA9800XKW2
Whirlpool LA9800XKW3
Whirlpool LA9800XKW4
Whirlpool LA9800XMW0
Whirlpool LA9800XPW0
Whirlpool LA9800XPW1
Whirlpool LA9800XSW1
Whirlpool LA9800XSW2
Whirlpool LA9800XTF0
Whirlpool LA9800XTF1
Whirlpool LA9800XTG0
Whirlpool LA9800XTG1
Whirlpool LA9800XTM0
Whirlpool LA9800XTM1
Whirlpool LA9800XTN0
Whirlpool LA9800XTN1
Whirlpool LA9800XTW0
Whirlpool LA9800XTW1
Maytag LA9900 Washer - Top Loading
Whirlpool LAA3340W0
Whirlpool LAA3340W1
Whirlpool LAA4000W0
Whirlpool LAA4005W0
Whirlpool LAA5000W0
Whirlpool LAA5000W1
Whirlpool LAA5300W0
Whirlpool LAA5300W1
Whirlpool LAA5300W2
Whirlpool LAA5305W0
Whirlpool LAA5305W1
Whirlpool LAA5380W0
Whirlpool LAA5380W2
Whirlpool LAA5380W3
Whirlpool LAA5500W0
Whirlpool LAA5500W1
Whirlpool LAA5500W2
Whirlpool LAA5505W0
Whirlpool LAA5505W1
Whirlpool LAA5505W2
Whirlpool LAA5520W0
Whirlpool LAA5520W1
Whirlpool LAA5520W2
Whirlpool LAA5525W0
Whirlpool LAA5525W1
Whirlpool LAA5525W2
Whirlpool LAA5540W6
Whirlpool LAA5545W6
Whirlpool LAA5600W0
Whirlpool LAA5600W2
Whirlpool LAA5600W3
Whirlpool LAA5605W0
Whirlpool LAA5605W2
Whirlpool LAA5605W3
Whirlpool LAA5700W1
Whirlpool LAA5700W2
Whirlpool LAA5700W3
Whirlpool LAA5700W4
Whirlpool LAA5700W5
Whirlpool LAA5705W1
Whirlpool LAA5705W2
Whirlpool LAA5705W3
Whirlpool LAA5705W4
Whirlpool LAA5705W5
Whirlpool LAA5800W0
Whirlpool LAA5800W1
Whirlpool LAA5800W2
Whirlpool LAA5800W4
Whirlpool LAA5800W5
Whirlpool LAA5800W6
Whirlpool LAA5800W7
Whirlpool LAA5805W1
Whirlpool LAA5805W2
Whirlpool LAA5805W4
Whirlpool LAA5805W5
Whirlpool LAA5805W6
Whirlpool LAA5805W7
Whirlpool LAA6800W1
Whirlpool LAA6805W1
Whirlpool LAA7000W0
Whirlpool LAA7005W0
Whirlpool LAA7500W0
Whirlpool LAA7500W1
Whirlpool LAA7505W0
Whirlpool LAA7505W1
Whirlpool LAA7700W0
Whirlpool LAA7700W1
Whirlpool LAA7700W2
Whirlpool LAA7705W0
Whirlpool LAA7705W1
Whirlpool LAA7705W2
Whirlpool LAA7800W0
  #2 (permalink)
Old 05-27-2008, 02:20 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Check for lateral play in the motor bearings, post results.
__________________
  #3 (permalink)
Old 05-27-2008, 04:13 PM
Junior Member
Default
After checking, I don't think it's the bearings. I think what I heard was the centrifugal switch. I 'm going to replace the coupling while I'm waiting for replies.
thank you,
Bill
  #4 (permalink)
Old 05-28-2008, 03:42 AM
Senior Expert
APP Volunteer
Default
Turn the tranny coupler several times, you may find the brake shoes stick sometimes, and then don't stick.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirpool washer jjab500 Washer Repair 1 07-21-2009 04:41 PM
whirpool washer vecaz Washer Repair 3 05-10-2009 06:39 AM
Whirpool washer richard mason Washer Repair 1 01-05-2009 06:18 PM
Whirpool Washer oanh le Dishwasher Repair 1 12-15-2008 07:29 PM
whirpool washer Bennie Washer Repair 1 02-23-2008 09:10 AM
