| » Whirpool washer won't run |
Model Number: la9500xtw1 Brand: Whirlpool Age: More than 10 years
Washer was running but when wash cycle was complete would not pump out water nor agitate. There seems to be a loud humming when it should be working.
I just replaced the water inlet valves and was working fine. However, we did hear a 'new' whinning when it was in the high spin cycle. I have check the lid switch with an ohm meter. I opened the control panel and disconnected the lip switch connector. It seems to be operating correctly. zero ohms when closed and infinite when open. I pulled the pump. It turns freely. I pulled the motor and inspected the coupler. The rubber coupling shows wear but is still in one piece. All three prongs look good on both ends. I turned the prongs going into the trans and everything seems to move smoothly. I turned the motor shaft manually. When I reverse directions there is a loud click from the shaft bearings. I think it's too loud. Is there anyway i can safely bench test the motor? Maybe it's just the starter capacitor? While waiting for a reply I'm going to remove the bear cap on the motor shaft to see if any bearings fall out. What a way to spend a Memorial Day weekend. Bill |
| Display Modes | |
| Whirpool washer top loader | rob777 | Washer Repair | 1 | 03-19-2008 01:40 PM |
| Whirpool clothes washer not draining | handypete | Washer Repair | 2 | 03-19-2008 11:47 AM |
| whirpool washer | Bennie | Washer Repair | 1 | 02-23-2008 10:10 AM |
| Whirpool Duet Washer | mansoor ali | Washer Repair | 1 | 12-16-2007 08:45 PM |
| Need clean cloths, whirpool washer | smurzynski | Washer Repair | 1 | 08-06-2007 05:50 PM |
