Washer has been having issues with spinning. I had to stop using the extra rinse cycle, it worked for a while and now it wont spin at all. I pulled it apart and checked the drive coupling and that is fine. Dont know where to go from there. Thanks!
First check the lid switch. It won't spin if the switch is open.
Motor comes on and it sounds like its spinning, but the basket does not move. Even if i move it by hand to begin with, which used to work.
It's probably the clutch.
Originally Posted by: magician59 It's probably the clutch. how do you get at the lid switch?
I beilieve that you are correct because when i had the cover off i noticed oil on the inside of the cover on both sides. Thanks for your assistance.
