Washer won't do anything. Used to set the timer, pull the knob out, close the lid and it started. Nothing now. 1. How do I get to the insides to check switches and fuses? 2. How do I get to the timer and take it out if it is bad?
A lot of the controls will be visible when you remove the panel at the front, between the washer and dryer.
