Discuss
Snubber Replacement on Frigidaire Washer
 in
Washer Repair
Hi, I'm trying to clean / replace the snubber on my Frigidaire washer model # FWX445RFS3 due to high screaching
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Snubber Replacement on Frigidaire Washer
  #1 (permalink)
Old 05-23-2008, 01:07 PM
Junior Member
skylarbeach is on a distinguished road
Default Snubber Replacement on Frigidaire Washer
Model Number: FWX445RFS3   Brand: Frigidaire   Age: 5 - 10 years
I'm trying to clean / replace the snubber on my Frigidaire washer model # FWX445RFS3 due to high screaching noise during spin cycle. Once the front and top are off I have access to the snubber however I can't seem to raise the tub high enough to remove it.
Any ideas?
Thanks in advance,
Greg
Ads By Google
Related Models
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
Frigidaire FWX445RFT4 Frg(v2) / Free Standing Washer
Frigidaire FWX645DBD0 Frg(v2) / 27 " Washer
Frigidaire FWX645DBD1 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW0 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW1 Frg(v2) / 27 " Washer
Frigidaire FWX645GES0 Frg(v0) / Washer
Frigidaire FWX645GES1 Frg(v0) / Washer
Frigidaire FWX645LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX645LBS2 Frg(v4) / Washer
Frigidaire FWX645LBS3 Frg(v3) / Washer
Frigidaire FWX645LBS4 Frg(v1) / Washer
Frigidaire FWX645LBT2 Frg(v5) / Washer
Frigidaire FWX645LBT4 Frg(v2) / Washer
Frigidaire FWX645NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS1 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS2 Frg(v2) / Washer
Frigidaire FWX645NBS3 Frg(v0) / Washer
Frigidaire FWX645NBT0 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT1 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT2 Frg(v3) / Washer
Frigidaire FWX645RFS0 Frg(v0) / Washer
Frigidaire FWX645RFS1 Frg(v0) / Washer
Frigidaire FWX6968HW0 Frg(v0) / Washer
Frigidaire FWX6970EW0 Frg(v0) / Washer
Frigidaire FWX6970EW1 Frg(v0) / Washer
Frigidaire FWX6970EW2 Frg(v0) / Washer
Frigidaire FWX6970EW3 Frg(v0) / Washer
Frigidaire FWX6970EW4 Frg/washer
Frigidaire FWX6970EW5 Frg(v0) / Washer
Frigidaire FWX6971EW0 Frg(v0) / Washer
Frigidaire FWX6971EW1 Frg(v0) / Washer
Frigidaire FWX6971EW2 Frg(v0) / Washer
Frigidaire FWX6975EW0 Frg(v0) / Washer
Frigidaire FWX6975EW1 Frg(v0) / Washer
Frigidaire FWX6975EW2 Frg(v0) / Washer
Frigidaire FWX833AS0 Washer - Frigidaire
Frigidaire FWX833AS1 Washer - Frigidaire
Frigidaire FWX833AS2 Frigidaire/washer
Frigidaire FWX833AS3 Frigidaire/washer
Frigidaire FWX833MAS0 Frigidaire/washer
Frigidaire FWX833SAQ0 Washer - Frig/gallery
Frigidaire FWX833SAS0 Washer - Frig/gallery
Frigidaire FWXB23RGS0 Frg(v0) / Washer
Frigidaire FWXB45RGS0 Washer - Frig/best Buy
Frigidaire FWXB45RGS1 Washer - Frig/best Buy
Frigidaire FWY833KAS0 Frigidaire/washer
Frigidaire FWY833KCS0 Frigidaire/washer
Maytag G Range - S/c F/s Gas
Hardwick G-433 Surface Unit - Ele
Hardwick G-436 Surface Unit - Ele
Hardwick G-445 Surface Unit - Ele
Jenn-Air G0206B-8 Electric Grill Outdoor
Jenn-Air G100 Surface Unit - Ddraft Ele
Jenn-Air G101 Surface Unit - Ddraft Ele
Jenn-Air G102 Surface Unit - Ddraft Ele
Jenn-Air G103 Surface Unit - Ddraft Ele
International G1110PRA Range - F/s Std Gas
International G1110PRW Range - F/s Std Gas
Frigidaire G12W
Frigidaire G15W
Frigidaire G18W
Frigidaire G21CL0 Frg(v1) / Gas Range
Frigidaire G21CW0 Frg(v2) / Gas Range
Frigidaire G21CW2 Frg(v1) / Gas Range
Frigidaire G21CW3 Frg(v2) / Gas Range
Frigidaire G21PCL0 Frg(v1) / Gas Range
Frigidaire G21PCL1 Frg(v3) / Gas Range
Frigidaire G21PCL3 Frg(v2) / Gas Range
Frigidaire G21PCL4 Frg(v2) / Gas Range
Frigidaire G21PCL5 Frg(v4) / Gas Range
Frigidaire G21PCW0 Frg(v2) / Gas Range
Frigidaire G21PCW1 Frg(v4) / Gas Range
Frigidaire G21PCW3 Frg(v1) / Gas Range
Frigidaire G21PCW4 Frg(v1) / Gas Range
Frigidaire G21PCW5 Frg(v3) / Gas Range
Frigidaire G22W
Frigidaire G24CL0 Frg(v1) / Free Standing Gas Range
Frigidaire G24CL3 Frg(v2) / Gas Range
Frigidaire G24CL4 Frg(v4) / Gas Range
Frigidaire G24CW0 Frg(v2) / Free Standing Gas Range
Frigidaire G24CW3 Frg(v1) / Gas Range
Frigidaire G24CW4 Frg(v3) / Gas Range
Frigidaire G24PCL0 Frg(v3) / Gas Range
Frigidaire G24PCL1 Frg(v5) / Gas Range
Frigidaire G24PCL3 Frg(v2) / Gas Range
Frigidaire G24PCL4 Frg(v4) / Gas Range
Frigidaire G24PCW0 Frg(v4) / Gas Range
Frigidaire G24PCW1 Frg(v6) / Gas Range
Frigidaire G24PCW3 Frg(v1) / Gas Range
Frigidaire G24PCW4 Frg(v3) / Gas Range
Frigidaire G25BNL0 Frg(v2) / Gas Range
Frigidaire G25BNW0 Frg(v1) / Gas Range
Frigidaire G30BCL2 Frg(v2) / Gas Range
Frigidaire G30BCW1 Frg(v1) / Gas Range
Frigidaire G30CL0 Frg(v5) / Gas Range
Frigidaire G30CL2 Frg(v2) / Gas Range
Frigidaire G30CL3 Frg(v4) / Gas Range
Frigidaire G30CW0 Frg(v6) / Gas Range
Frigidaire G30CW2 Frg(v1) / Gas Range
Frigidaire G30CW3 Frg(v3) / Gas Range
Frigidaire G30LPNL1 Frg(v2) / Gas Range
Frigidaire G30LPNL2 Frg(v2) / Gas Range
Frigidaire G30LPNL3 Frg(v2) / Gas Range
Frigidaire G30LPNW1 Frg(v1) / Gas Range
Frigidaire G30LPNW2 Frg(v1) / Gas Range
Frigidaire G30LPNW3 Frg(v1) / Gas Range
Frigidaire G30NL1 Frg(v1) / Gas Range
Frigidaire G30NL2 Frg(v2) / Gas Range
Frigidaire G30NL3 Frg(v3) / Gas Range
Frigidaire G30NL4 Frg(v4) / Gas Range
Frigidaire G30NL5 Frg(v2) / Gas Range
Frigidaire G30NL6 Frg(v2) / Gas Range
  #2 (permalink)
Old 05-23-2008, 07:49 PM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Easy
Remove the springs
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Snubber questio governor Washer Repair 3 12-02-2009 03:11 PM
install snubber- kenmore washer heavy duty 70 cathy7 Washer Repair 1 08-31-2009 12:31 PM
Amana Washer - Snubber replacement 5GMs Washer Repair 13 11-29-2008 02:22 PM
