Discuss
Kemore elite washer makes humming sound at spin cycle
 in
Washer Repair
My machine is full of water and clothes - when I turn the dial to spin cycle - it just
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kemore elite washer makes humming sound at spin cycle
  #1 (permalink)
Old 03-06-2010, 08:29 AM
Junior Member
aviator2010 is on a distinguished road
Default Kemore elite washer makes humming sound at spin cycle
Model Number: 110.24952300   Brand: Kenmore   Age: 5 - 10 years
My machine is full of water and clothes - when I turn the dial to spin cycle - it just makes a humming sound and stops. Unplugging and replugging in the unit - the unit continues to do the same thing. Governing the age of the unit ... thinking of getting some else here - 5 years old ... but is there an easy fix to this problem ? any advisement appreciated.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 03-06-2010, 05:51 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
This machine should have plenty of life left in it, and most repairs are very easy but we need more info.
Specifically, does it agitate and/or drain. If it will not agitate, nor drain when the dial is set for spin you probably have something jamming the pump.
Pull off the pump, check it out and get the obstruction out of replace it.
This site will show you how to remove the cabinet and the pump for checking.
If it will drain, but not agitate or spin the coupling may be the problem.
This site will show you how to deal with that also.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
__________________
  #3 (permalink)
Old 03-06-2010, 07:53 PM
Junior Member
Default
Thanks very much for the response - the machine will neither drain nor agitate ... so I will check the pump - I talked to someone stupidly (likely
looking for a sale) at an actual appliance store - not the likes of Sears, Lowes or any of these wannabees - who told me it was likely the gear box !! - I had read somewhere that it could be the pump - so I have nothing to lose here - I 'll take a look at this tomorrow. Thanks !!
  #4 (permalink)
Old 03-07-2010, 06:32 AM
Senior Expert
APP Volunteer
Default
Great, just so you know all that water is going to come out when you take off the pump so be prepared.
It could still be the motor or transmission but let's hope it is something simple like the pump or coupling jammed.
__________________
  #5 (permalink)
Old 03-07-2010, 11:55 AM
Junior Member
Default thank you !!
Found a socking sock stuck in the pump - thanks very much for the tip - it is now working - the hum was likely from the motor as it could not turn .... big thank you !!
  #6 (permalink)
Old 03-07-2010, 12:06 PM
Junior Member
Default
Thanks for the tip also about watching for a ton of water ... upon pump disconnection - I emptied it
yesterday with a wet-dry vac as it was full of water - it would have been
swim city otherwise !! Big thanks !
  #7 (permalink)
Old 03-07-2010, 01:11 PM
Senior Expert
APP Volunteer
Default
That's great, pulled one out of pump just this week myself.
Thanks for the update, glad you got fixed and good luck going forward.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer makes humming sound grice98 Dryer Repair 1 03-23-2009 03:29 PM
Dryer Makes Humming Sound ASTRO1954 Dryer Repair 4 03-15-2009 08:45 AM
disposal makes humming sound/won't work lilmama Garbage Disposer Repair 1 03-12-2009 04:24 PM
makes a humming sound when on angel4022 Oven Repair (including Ranges and Cooktops) 1 01-27-2009 11:10 AM
Dryer makes humming sound when turning cycle selector skull Dryer Repair 3 01-17-2009 09:15 AM
