Jeff40
#1 Posted : Thursday, May 22, 2008 5:06:49 PM(UTC)
Jeff40
I replaced the circuit board ( it went out 2 times already) after that did not work I actually did trouble shooting, I have power and the lid switch appears to work, all I can assume is the timer is bad since no power is comming out of it.
#2 Posted : Friday, May 23, 2008 2:16:55 AM(UTC)
Replace the white lid switch P # AP3159413 Take note how the switch is mounted so you get the new one in properly.
Jeff40
#3 Posted : Wednesday, May 28, 2008 4:43:23 PM(UTC)
Jeff40
It seems as if the lid switch is working, I tested it with a meter and when I open the lid it measures no power, with that happining doesn't that indicate the switch is working properly?
#4 Posted : Thursday, May 29, 2008 2:25:08 AM(UTC)
These switches will test good, but there is a internal thermal link that likes to blow out, just replace it.
Jeff40
#5 Posted : Thursday, May 29, 2008 3:51:22 PM(UTC)
Jeff40
Thanks for that info, I odrded the switch last night based on your advice, I'll let you know how it goes.
