this washer has been working good for 4 years {used} and i have not had any problems with it, until a month ago. this is when it started running cold water only. i presume it would be the temperature control switch.. please help me..
Thank You:D
Here are your parts Replacement parts for FRIGIDAIRE GLWS1749AS2 Washer - Frig Gallery | AppliancePartsPros.comHere is the wiring diagram http://manuals.frigidaire.com/prodinfo_pdf/Webster/134125600.pdf[COLOR="Blue"]i presume it would be the temperature control switch.[/COLOR] Not necessarily. Could be something as simple as a clogged screen filter on the input side of the hot valve. Does it do this on a hot/cold temperature select? It looks like the unit does not use the board on this setting. If it does give hot water then your problem may be the board. If it does not give hot water. Remove the hose at the hot water tap and run some water into a pail. If OK Reattach the hose and run some water through it into a pail Also check that the screen filter on the input side of the hot water valve is clean. If not clean it. Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood. If OK Unplug the unit and swap the wires from the hot to the cold valves. Leave the Red/Blacks as it is common to both valves. Plug the unit in and give it a try. Now if there is no hot water you know that the hot side of the valve is no good since you already know that the cold side does get power but the hot valve does not open. |
THIS FORUM IS DEAD!!!!!!! |
