Changed out ecu and door now works properly but during the cycle machine will stop and timer flashes. The machine will eventually restart and then go through the flash cycle again occassionally giving me F06. Ran dianostic and everything cycled properly. When it runs it takes much longer than what the timer says. Do I need to change out the user control panel?
You should have come accross a tech sheet in your repair. See if you can troubleshoot the machine, focusing on the wiring between the MCU and the CCU and the MCU itself.
You may also have door lock issues, so check it also.
