All I can get my washer to do is fill. I can spin the timer/cycle knob to start, spin or rinse and all it does is fill. It will not spin on any cycle, just fill. And I'm tired of bailing water. Any suggestions would be greatly appreciated. Thank you. madchase.
The lid switch is the first thing you want to test, either to replace or rule it out as a problem.
Originally Posted by: sidfink43 The lid switch is the first thing you want to test, either to replace or rule it out as a problem. Thank you sidfink43 for your time and responce. I just decided to take the easy way out and got another washing machine. Thank you again, and if I ever have any more problems I will be sure to come back here. madchase1.:D
Well, good luck with your new machine, and thanks for the update.
