Discuss
Washer Flange Torn Away
 in
Washer Repair
Hiya, Ive had this washer now for 14 months and only recently ive noticed plastic in the filter, looks like
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Flange Torn Away
  #1 (permalink)
Old 03-04-2010, 08:11 AM
Junior Member
supernova is on a distinguished road
Default Washer Flange Torn Away
Model Number: CM1 146   Brand: -other-   Age: 1 - 5 years
Hiya,
Ive had this washer now for 14 months and only recently ive noticed plastic in the filter, looks like chewed up plastic. it started leeking from the bottom thats how i noticed the problem. It seems like the flange (drum casing) has been either been melting or ripped away. It connects to the door seal by tension wire so that has been ruined to.
I took washer apart and found that it was the only damaged caused. i ordered the parts and got them fitted with alot of effort.
Everything is back where it should be and thought it was working fine until the same thing started happening. Bits of plastic are appearing in the filter and i can see it coming away from the flange again.
It has cost be a bit to replace these bits up to now so im seeking advice before i start buying more bits that are not needed.
Has anyone had this problem before or come across it? Not sure if you can put photos on here as that would help to understand what it is.
Ads By Google
Related Models
Jenn-Air CM100 Surface Base Unit - Ddraft Ele
Jenn-Air CM100-E Surface Base Unit - Ddraft Ele
Crosley CM151 Mwave - Cntrtp / Stand Alone
Crosley CM153 Mwave - Cntrtp / Stand Alone
Magic Chef CM15K-7BS-NB Mwave - Mounted Over Range/wo
Magic Chef CM15KW-7BS-NB Mwave - Mounted Over Range/wo
Jenn-Air CM200 Surface Base Unit - Ddraft Ele
Jenn-Air CM200-E Surface Base Unit - Ddraft Ele
Thermador CM301B
Thermador CM301S
Thermador CM301W
Thermador CM302B
Thermador CM302S
Thermador CM302W
Crosley CM464G Mwave - Cntrtp / Stand Alone
Magic Chef CM46B-9P Mwave - Mounted Over Range/wo
Magic Chef CM46B-9P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46D-8P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46D-9P Mwave - Mounted Over Range/wo
Magic Chef CM46D-9P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46F-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46F-8P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46FN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46FN-8P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46G-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46GN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46H-14T Mwave - Mounted Over Range/wo
Magic Chef CM46HW-14T Mwave - Mounted Over Range/wo
Magic Chef CM47F-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM47FN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM47H-14T Mwave - Mounted Over Range/wo
Magic Chef CM47HW-14T Mwave - Mounted Over Range/wo
Magic Chef CM47J-14T Mwave - Mounted Over Range/wo
Magic Chef CM47JW-14T Mwave - Mounted Over Range/wo
Magic Chef CM48F-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM48FN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM48H-14T Mwave - Mounted Over Range/wo
Magic Chef CM48HW-14T Mwave - Mounted Over Range/wo
Magic Chef CM48J-14T Mwave - Mounted Over Range/wo
Magic Chef CM48JW-14T Mwave - Mounted Over Range/wo
Amana CM601.000 Commercial Microwaves
Amana CM601.A Commercial Microwaves
Hardwick CM9641A590R Range - F/s Std Gas
Hardwick CM9641W590R Range - F/s Std Gas
Hardwick CM9641Y590R Range - F/s Std Gas
Amana CMA2000 Commercial Microwaves
Amana CMA2000B3 Commercial Microwaves
Amana CMA2000BK Commercial Microwaves
Amana CMA2230 Commercial Microwaves
Amana CMA2230B3 Commercial Microwaves
Maytag CME300 Mwave - Cntrtp / Stand Alone
Maytag CME301 Mwave - Cntrtp / Stand Alone
Maytag CME400 Mwave - Cntrtp / Stand Alone
Maytag CME500 Mwave - Cntrtp / Stand Alone
Maytag CME501 Mwave - Cntrtp / Stand Alone
Maytag CME601 Mwave - Cntrtp / Stand Alone
Maytag CME700 Mwave - Cntrtp / Stand Alone
Maytag CME701 Mwave - Cntrtp / Stand Alone
Maytag CME800 Mwave - Cntrtp / Stand Alone
Maytag CME8000AAB Mwave - Cntrtp / Stand Alone
Maytag CME8000AAE Mwave - Cntrtp / Stand Alone
Maytag CME8010AAB Mwave - Cntrtp / Stand Alone
Maytag CME8010AAE Mwave - Cntrtp / Stand Alone
Maytag CME900 Mwave - Cntrtp / Stand Alone
Maytag CME901 Mwave - Mounted Under Cabinet
Maytag CME9010AAB Mwave - Mounted Under Cabinet
Maytag CME9010AAE Mwave - Mounted Under Cabinet
Maytag CME9010BAB Mwave - Mounted Under Cabinet
Maytag CME9010BAE Mwave - Mounted Under Cabinet
Maytag CME9010CAB Mwave - Mounted Under Cabinet
Maytag CME9010CAE Mwave - Mounted Under Cabinet
Maytag CME9010CAM Mwave - Mounted Under Cabinet
Maytag CME9010DAB Mwave - Mounted Under Cabinet
Maytag CME9010DAE Mwave - Mounted Under Cabinet
Uni CMEF212EB1 Universal Canada/electric Range
Uni CMEF212EB2 Universal Canada/electric Range
Uni CMEF212EB3 Universal Canada/electric Range
Uni CMEF212EQ1 Universal Canada/electric Range
Uni CMEF212ES1 Universal Canada/electric Range
Uni CMEF212ES2 Universal Canada/electric Range
Amana CMM2000C Commercial Microwaves
Menu Master CMM2000C  Commercial Microwaves
Amana CMM2000CS Commercial Microwaves
Amana CMM2230C Commercial Microwaves
Amana CMM2230CS Commercial Microwaves
Amana CMP1.A Commercial Microwaves
Maytag CMS130BCLWH  Freezer - Vertical
Maytag CMS180BCLWH  Freezer - Vertical
Maytag CMS210ACLWH Freezer - Vertical
Maytag CMS210ADLWH Freezer - Vertical
Maytag CMS210BCLWH Freezer - Vertical
Thermador CMT-127
Thermador CMT-131
Thermador CMT-18
Thermador CMT-19
Thermador CMT-19 SERVICE CODE H & UP
Thermador CMT-20
Thermador CMT-21
Thermador CMT-21 SERVICE CODE J & UP
Thermador CMT-227
Thermador CMT-231
Whirlpool CMT061SGW0
Whirlpool CMT101SGW0
Whirlpool CMT102SGW0
Thermador CMT127N-01
Whirlpool CMT135SGW0
Thermador CMT227N-01
Thermador CMT227W
Thermador CMT231-01 S/N 89110145 & UP
Maytag CMV1000ADA Mwave - Mounted Under Cabinet
Maytag CMV1000ADB Mwave - Mounted Under Cabinet
Maytag CMV1000ADW Mwave - Mounted Under Cabinet
Maytag CMV1000BAB Mwave - Mounted Under Cabinet
Maytag CMV1000BAQ Mwave - Mounted Under Cabinet
Maytag CMV1000BAW Mwave - Mounted Under Cabinet
Maytag CMV1000BDB Mwave - Mounted Under Cabinet
Maytag CMV1000BDQ Mwave - Mounted Under Cabinet
Maytag CMV1000BDW Mwave - Mounted Under Cabinet
Maytag CMV1100AAB Mwave - Mounted Under Cabinet
Maytag CMV1100AAQ Mwave - Mounted Under Cabinet
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Torn Gasket GE Adora Front Loader Washer rsegalla@verizon.net Washer Repair 0 12-30-2009 08:14 AM
Torn gasket gatman Washer Repair 1 03-27-2009 06:09 PM
Flange snap ring not holding, specialty flange wranglerbrat Garbage Disposer Repair 0 11-27-2008 10:57 AM
Replace disposal flange redfox Garbage Disposer Repair 2 03-30-2008 01:22 PM
Torn clothing jenwith4kids Washer Repair 1 02-11-2008 10:09 AM
