Discuss
Washer
 in
Washer Repair
The spin cycle didn"t work but there was a loud noise and something spinning could be heard. What could it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer
  #1 (permalink)
Old 05-21-2008, 03:50 PM
Junior Member
Johndym is on a distinguished road
Default Washer
Model Number: LDA6900W0   Brand: Whirlpool   Age: More than 10 years
could be heard. What could it be on this old machine(20 some years)?
How can I get to it?
Ads By Google
Related Models
Whirlpool LDA6900W0
Whirlpool LDA6900W1
Whirlpool LDA6905W0
Whirlpool LDA6905W1
Whirlpool LDA7000W0
Whirlpool LDA7000W1
Whirlpool LDA7000W2
Whirlpool LDA7005W0
Whirlpool LDA7005W1
Whirlpool LDA7005W2
Whirlpool LDA7500W0
Whirlpool LDA7500W1
Whirlpool LDA7505W0
Whirlpool LDA7505W1
Whirlpool LDA7600W0
Whirlpool LDA7600W1
Whirlpool LDA7600W2
Whirlpool LDA7600W3
Whirlpool LDA7605W0
Whirlpool LDA7605W1
Whirlpool LDA7605W2
Whirlpool LDA7605W3
Whirlpool LDA7700W0
Whirlpool LDA7700W1
Whirlpool LDA7700W2
Whirlpool LDA7705W0
Whirlpool LDA7705W1
Whirlpool LDA7705W2
Whirlpool LDA7800W0
Whirlpool LDA7800W1
Whirlpool LDA7800W2
Whirlpool LDA7800W3
Whirlpool LDA7805W0
Whirlpool LDA7805W1
Whirlpool LDA7805W2
Whirlpool LDA7805W3
Whirlpool LDA7900W0
Whirlpool LDA7900W1
Whirlpool LDA8000W0
Whirlpool LDA8005W0
Whirlpool LDA8800W0
Whirlpool LDA8800W1
Whirlpool LDA8800W2
Whirlpool LDA8800W3
Whirlpool LDA8805W0
Whirlpool LDA8805W1
Whirlpool LDA8805W2
Whirlpool LDA8805W3
Whirlpool LDA9800W0
Whirlpool LDA9800W1
Whirlpool LDA9800W3
Whirlpool LDA9800W4
Whirlpool LDA9805W3
Whirlpool LDA9805W4
Whirlpool LDB5150W0
Whirlpool LDB5150W1
Whirlpool LDB5300W0
Whirlpool LDB5300W1
Whirlpool LDB5300W2
Whirlpool LDB5500W0
Whirlpool LDB5500W1
Whirlpool LDB5500W2
Whirlpool LDB5500W3
Whirlpool LDB7750W0
Whirlpool LDB7750W1
Whirlpool LDB7750W2
International LDE1000ACE Dryer - Ele
International LDE1000AKE Dryer - Ele
International LDE1000GGE Dryer - Ele
Maytag LDE107 Dryer - Ele
Maytag LDE110 Dryer - Ele
Maytag LDE18CA Dryer - Ele
Maytag LDE18CM Dryer - Ele
Maytag LDE18CS Dryer - Ele
Maytag LDE18CT Dryer - Ele
Maytag LDE19CA Dryer - Ele
Maytag LDE19CD Dryer - Ele
Maytag LDE19CS Dryer - Ele
Maytag LDE19CT Dryer - Ele
Maytag LDE210 Dryer - Ele
Maytag LDE212 Dryer - Ele
Maytag LDE212D Dryer - Ele
Maytag LDE21CS Dryer - Ele
Maytag LDE22CS Dryer - Ele
Maytag LDE22CT Dryer - Ele
Maytag LDE23CD Dryer - Ele
Maytag LDE24CA Dryer - Ele
Maytag LDE24CM Dryer - Ele
Maytag LDE24CS Dryer - Ele
Maytag LDE24CT Dryer - Ele
Maytag LDE25CS Dryer - Ele
Maytag LDE26CA Dryer - Ele
Maytag LDE26CD Dryer - Ele
Maytag LDE26CS Dryer - Ele
Maytag LDE26CT Dryer - Ele
Maytag LDE27CA Dryer - Ele
Maytag LDE27CD Dryer - Ele
Maytag LDE27CS Dryer - Ele
Maytag LDE27CT Dryer - Ele
Whirlpool LDE3000W0
Maytag LDE303 Dryer - Ele
Maytag LDE303D Dryer - Ele
Maytag LDE306 Dryer - Ele
Maytag LDE308 Dryer - Ele
Maytag LDE309 Dryer - Ele
Maytag LDE312 Dryer - Ele
Maytag LDE312D Dryer - Ele
Maytag LDE313 Dryer - Ele
Maytag LDE313D Dryer - Ele
Frigidaire LDE333PBW0 Frg(v0) / Gas Dryer
Frigidaire LDE333PBW1 Frg(v0) / Electric Dryer
Frigidaire LDE333PEW0 Frg(v0) / Electric Dryer
Maytag LDE382 Dryer - Ele
Maytag LDE4000 Dryer - Ele
Maytag LDE4000ACL Dryer - Ele
Maytag LDE4000ACW Dryer - Ele
Maytag LDE4000ADL Dryer - Ele
Maytag LDE4000ADW Dryer - Ele
Maytag LDE406 Dryer - Ele
Maytag LDE408 Dryer - Ele
  #2 (permalink)
Old 05-21-2008, 04:36 PM
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
does it wash? open back cover .check large pulley on right side, see if it wobbles.
__________________
  #3 (permalink)
Old 05-21-2008, 05:36 PM
Junior Member
Default
Quote:
There's only a small panel in the back lower left about 151/2"x151/2".
I took it off and only saw the motor, tub and some electrical components
but no pulley. The washer did go through some of the wash cycle if not all
but it would not spin in the rinse cycle.
Sorry,I looked again and saw a very obvious large pulley on the right
and a small pulley on the left.The belt seems to be in good condition
and it can be turned easily by hand. The pullies have no wobble.
  #4 (permalink)
Old 05-22-2008, 03:43 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Lift up the outer spin solenoid plunger and turn the belt. The slide should move to engage the clutch and the basket should start spinning. Post results.
__________________
  #5 (permalink)
Old 05-22-2008, 07:00 AM
Junior Member
Default Washer
Richappy,
What does the outer spin solenoid look like and where is it?
  #6 (permalink)
Old 05-22-2008, 06:11 PM
Junior Member
Default Washer
I'm still not sure what the outer spin solenoid plunger is. can someone help
me on this so that I can try what Richappy suggested?
  #7 (permalink)
Old 05-23-2008, 03:13 AM
Senior Expert
APP Volunteer
Default
You have a dual solenoid mounted to the transmission. Just lift up the plunger on the solenoid on the left side next to the side wall. Then pull the belt clockwise till it goes into spin.
__________________
  #8 (permalink)
Old 05-23-2008, 07:36 AM
Junior Member
Default Washer
richappy,
The diagram for this model doesn't show a transmission. Only a motor and
pump assembly are attached to the pulley. I'm still confused on this.
  #9 (permalink)
Old 05-23-2008, 11:06 AM
Junior Member
Default
I looked at the thread by debjames and looked up the Model#. The parts
look closer to what I see than for the model # on my machine. It could be some of the parts could have been changed by the repairman we bought it from over 20 years ago.
I see two cam bars and two plungers. I tried lifting them both one at a time,
while turning the belt from right to left until one or the other would stay up.
The result is that I believe the inner most plunger (further away from the
panel door) controls the spin. So I turned the belt while holding that plunger up until the belt tightened and could no longer be turned. The plunger would then stay up. I turned on the machine to approximately the spin cycle and it started to spin for a few turns then stopped spinning but the
belt was still turning.
I repeated this with the plunger toward the door. It took a number of turns before this plunger would stay up but the belt did not tighten as with the
other plunger. It very weakly agitated but then stopped and the belt was
still turning.
Is this repairable or am I looking at another washer? If so, any recommendations on washers (new or used)?
I forgot to mention that I did these tests with the water turned off. Does this make a difference?
  #10 (permalink)
Old 05-24-2008, 03:40 AM
Senior Expert
APP Volunteer
Default
If the motor is turning in spin, you either have a broken wire at the solenoid, a bad solenoid, or a bad timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 05:21 PM
is this model number washer a direct drive washer dandjwashington Washer Repair 2 05-01-2009 07:26 PM
Change Washer Lid Switch on Stacked Washer/Dryer scottcomputers Washer Repair 1 05-01-2009 10:16 AM
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 0 11-30-2008 08:35 AM
