The washer won't spin. It does aggate and the pump works. I just replace the lid latch which was fried before (I mean real charcoal.) When the timer hits the spin cycle no action and I am afraid I will burn up the latch relay again. The new latch doesn't seem to lock the lid either. Should there be a signal from the timer to do this? The tub seems to be wobbely too. Is this normal? The motor is hot as well
