| » Dancing washer |
Model Number: PAV5000 Brand: Maytag Age: 5 - 10 years
My washer makes a loud banging noise and moves all over during the spin cycle. I checked and all the springs are intact. Not sure how tight the belt should be, but it was very loose. Can someone help me?
A common cause of your symptoms is a broken or damaged snubber. It is an inexpensive part but requires some work to replace, including special tools. If you do, make sure you have the right tool and be very careful, you are working with 200lbs of pressure.
Here is a service manual if you wish to have a go at it. http://www.servicematters.com/maytag...s/16023083.pdf
__________________
| Display Modes | |
| help how do you speciffically replace washer timer on Maytag washer | stupid1 | Washer Repair | 5 | 07-04-2009 05:21 PM |
| is this model number washer a direct drive washer | dandjwashington | Washer Repair | 2 | 05-01-2009 07:26 PM |
| Change Washer Lid Switch on Stacked Washer/Dryer | scottcomputers | Washer Repair | 1 | 05-01-2009 10:16 AM |
| maytag washer/dyer combo washer no water | lindavanzandt | Washer Repair | 0 | 11-30-2008 08:35 AM |
| Washer is "dancing" more these days | gustavio | Washer Repair | 6 | 04-05-2008 04:35 AM |
