Discuss
How to replace the shocks on a Whirlpool Duet
 in
Washer Repair
I need a little help replacing the shock absorbers on a whirlpool duet GHW9150PW0. Is this something an amateur can
Appliance Repair Forum > Appliance Repair Help > Washer Repair » How to replace the shocks on a Whirlpool Duet
  #1 (permalink)
Old 02-26-2010, 06:36 PM
Junior Member
TO_120 is on a distinguished road
Default How to replace the shocks on a Whirlpool Duet
Brand: Whirlpool   Age: 1 - 5 years
I need a little help replacing the shock absorbers on a whirlpool duet GHW9150PW0. Is this something an amateur can do or should I leave this to a professional?
Thanks!
Ads By Google
  #2 (permalink)
Old 02-28-2010, 07:27 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It is something you should be able to do, just take your time, and get a helper that you can boss around.
The main thing you need is step by step instructions from the service manual. Here it is. Take a look and see if your skills are up to the task, I bet they are.
https://secured.whirlpool.com/Servic...0Job%20Aid.pdf
__________________
  #3 (permalink)
Old 03-06-2010, 04:57 AM
Junior Member
Default
I was able to remove the top connections without a problem. The bottom connections in the front are not easy to access. Any suggestions?
  #4 (permalink)
Old 03-06-2010, 02:21 PM
Senior Expert
APP Volunteer
Default
If you take off the front you should be fine.
__________________
  #5 (permalink)
Old 04-02-2010, 03:48 PM
Junior Member
gogojojo is on a distinguished road
Default
Quote:
I am trying to do the same thing. Can you tell me how you were able to get the top connection off? It seems like you would need three hands. There are two tabs that you have to push down while turning the shock, right?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How To Replace A Baffle-Whirlpool Duet Washer gllooman Washer Repair 6 05-23-2010 10:54 AM
replacing drum shocks, whirlpool washer cvernick Washer Repair 1 02-09-2010 06:03 PM
changing the shocks on duet washer randydunbar Dishwasher Repair 0 12-20-2009 11:55 AM
How easy is it to replace the seal on the washer Whirlpool Duet? frostywashdry Washer Repair 11 04-29-2009 04:22 AM
Whirlpool Duet how to replace coils janmarhen Dryer Repair 0 11-09-2008 10:08 AM
