| » Maytag Neptune Front load washer |
Quote:
On the other side, if you are handy enough, you can replace just the bearing. You can find some useful information in one of our previous threads: Replacing Neptune bearings Here are the breakdown diagrams and Replacement parts for MAYTAG MAH4000AWW Washer - Horizontal Axis | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
You are welcome Mike. Good luck and keep us posted.
__________________
The wax motor is a part of the door latch and it has nothing to do with the bearing problem unless there is more problems with your washer.
__________________
I replaced my bearings after a lot of intensive web investigation. There is one important item that nobody talks about, that is, properly seating the drum. So I put up a web page on it at
neptune bearings hope this helps somebody because if those bearings are not seated water gets in and all is in vain. |
Quote:
Good luck with your washer. Gene.
__________________
| Display Modes | |
| Maytag Front Load Washer | dannyrwalls@yahoo.com | Washer Repair | 1 | 11-14-2009 05:46 PM |
| MAYTAG NEPTUNE FRONT LOAD WASHER, Clothes come out soaking wet | debbielf | Washer Repair | 3 | 09-01-2009 05:13 AM |
| Maytag Neptune Front Load Washer Help | debster101 | Washer Repair | 1 | 07-24-2009 10:31 AM |
| Maytag neptune front load shakes | yappy | Washer Repair | 0 | 03-20-2009 08:01 AM |
| Maytag Neptune front load Washer | castillocm | Dryer Repair | 1 | 07-31-2008 06:36 PM |
