2 Pages12>
Ramos
#1 Posted : Monday, May 19, 2008 9:23:48 AM(UTC)
Ramos
I would like some help is being able to tighten the spin belt on this magtag washer, can some one UserPostedImageplease help
ApplianceJunk
#2 Posted : Monday, May 19, 2008 10:06:12 AM(UTC)
ApplianceJunk
The idler wheel is self adjusting. There is no way to tighten the belt.
#3 Posted : Monday, May 19, 2008 1:31:14 PM(UTC)
I would remove the belt and turn the transmission pulley both ways to see if one direction is tight, if ok, check the pump for bad bearings. If everything ok, just replace the belt.
Ramos
#4 Posted : Tuesday, May 20, 2008 8:52:03 AM(UTC)
Ramos
Thanks for your help yesterday, I did see that there is not way to adjust the belt, also, I what I found was that the pulley wheel was at the bottom of the cabinet. My question is there some way to fasten the pulley wheel to the pulley lever? I managed to get the pulley wheel back in place but it will not stay there on it's own.
Thanks again for your help
Ramos
Ramos
#5 Posted : Tuesday, May 20, 2008 9:42:30 AM(UTC)
Ramos
thanks for you help, can you tell me if there is a way to fasten the pulley wheel to the lever idler arm??
Again thanks for all the help.
Ramos
Ramos
#6 Posted : Tuesday, May 20, 2008 9:43:54 AM(UTC)
Ramos
thanks again, I need to know if there is a way to fasten the pulley wheel to the lever idler arm??
Ramos
Ramos
#7 Posted : Tuesday, May 20, 2008 9:57:08 AM(UTC)
Ramos
Iam not sure if you are getting my replies. I would like to know if there is a way to fasten the pulley wheel to the lever idler arm. I found the pulley wheel on the bottom of the cabinet, put it back in the lever idler arm but I am not sure if it will stay with out some way to fasten it.
Thanks for you kindly help.
Ramos
#8 Posted : Tuesday, May 20, 2008 10:49:51 AM(UTC)
The "C" clip/retainer ring may have popped off the idler shaft, just look for it, or the pulley may be bad. C clip part # 23748, pulley part # 40045001
Ramos
#9 Posted : Wednesday, May 21, 2008 8:42:52 AM(UTC)
Ramos
thanks again, I will look for the the c retainer.. If not I may have to order one
Ramos
budney
#10 Posted : Thursday, October 2, 2008 7:13:15 AM(UTC)
budney
My neptune washer model MAH3000AWW makes a high pitch whirling sound during the final spin cycle. I think the bearing for the inner tub is going bad but I can not find a bearing on your parts breakdown.
Thanks russ rlney@msn.com
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Replacing a stacking Bosch Axxis+ Washer (Washer Repair)
by DonLafontaine 3/22/2024 3:59:06 AM(UTC)
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Amanda washer intermittently wont fill (Washer Repair)
by Guest 3/13/2024 3:48:07 PM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
Kenmore 80 Series washer, fast speed burning smell (Washer Repair)
by lwmi5870 3/9/2024 1:25:21 PM(UTC)
Opened lid to add something to washer after it started and now the cycle won’t start again (Washer Repair)
by Guest 2/25/2024 6:18:56 AM(UTC)
Maytag Bravos XL MCT Thrust washer (Washer Repair)
by EricP 2/21/2024 2:57:06 PM(UTC)
Maytag Bravos MCT Washer (Washer Repair)
by Guest 2/21/2024 12:53:32 PM(UTC)
GE Frontload Washer Spin (Washer Repair)
by mahgnibb 2/16/2024 6:13:51 AM(UTC)
2 Pages12>
