2 Pages<12
libertyappl
#11 Posted : Thursday, October 2, 2008 8:34:26 AM(UTC)
libertyappl
budney,
If it's a whirling sound check all the little holes inside the tub for anything that may be stuck in a hole(like a nail, screw, bra wire, etc....)
You will probably want to use a flash light to look. May get lucky and that's all it is.
Nat
chengsr
#12 Posted : Monday, February 2, 2009 10:29:59 AM(UTC)
chengsr
I had the tub replaced 3 years ago and lately during the final spin cycle a loud noise occurs and only during the final spin cycle. Is it possible that the strut is going bad?
#13 Posted : Monday, February 2, 2009 1:47:12 PM(UTC)
Is it a bearing noise, or a thumping sound.
chengsr
#14 Posted : Monday, February 2, 2009 5:05:55 PM(UTC)
chengsr
It starts with a 2 or 3 thump and then it turns into a bearing noise, I guess I answer my own question?
#15 Posted : Tuesday, February 3, 2009 12:32:25 AM(UTC)
I would pull the bottom front panel and check for a busted shock. Also, if you have an amprobe, check the total current into the washer at the power plug.
If the current draw in high speed spin is getting near 3 amps, your speed control board/motor will fail soon with continued running.
chengsr
#16 Posted : Tuesday, February 3, 2009 5:27:59 AM(UTC)
chengsr
Thanks, I had the inner tub, motor and motor controlbroard replace 3 years ago just wondering if there is any warranty on Magtag OEM parts.
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Whirlpool cabrio washer codes (Washer Repair)
by Guest 4/20/2024 11:59:12 AM(UTC)
LG washer not letting in cold water (Washer Repair)
by Cgrigson1 4/19/2024 7:34:57 AM(UTC)
Samsung top load washer won’t start (Washer Repair)
by aw2055989 4/19/2024 4:42:33 AM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag LA882 Washer (Dishwasher Repair)
by soloRepairer 3/30/2024 2:12:38 PM(UTC)
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Replacing a stacking Bosch Axxis+ Washer (Washer Repair)
by DonLafontaine 3/22/2024 3:59:06 AM(UTC)
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
2 Pages<12
