Discuss
kenmore 80 series washer not agitating
 in
Washer Repair
washer fills, spins, ok in clean section agitator only spins does not agitate back and forth and makes a grating
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore 80 series washer not agitating
  #1 (permalink)
Old 02-25-2010, 09:31 AM
Junior Member
david.graham is on a distinguished road
Default kenmore 80 series washer not agitating
Brand: -brand-   Age: Less than 1 year
in clean section agitator only spins does not agitate back and forth and makes a grating noise like gears sliping
Note. already checked the dogs and they are working fine, the noise sounds like metal gears not meshing correctly
the agitator does not turn in both directions, the dof teeth do engage
because during wash cycle it is only spinning in one direction, all the clothes get tagled tight roung the agitator
Ads By Google
  #2 (permalink)
Old 02-26-2010, 11:26 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
The symptoms you describe are a bad transmission. If you can post a model number we may be able to comment further.
__________________
  #3 (permalink)
Old 02-26-2010, 11:43 AM
Junior Member
Default model #
model # 110.20802-990
  #4 (permalink)
Old 02-26-2010, 11:45 AM
Junior Member
Default
model # 110.20802.990
Quote:
  #5 (permalink)
Old 02-26-2010, 12:30 PM
Senior Expert
APP Volunteer
Default
Ok, open it up using the instructions here
Kenmore top loader blues (SublimeMasterJW's Appliance Advice)
and try to listen to pinpoint the noise in the agitation cycle. If it is coming from the transmission area it is the transmision which will have to be replaced.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80's series not agitating leothedog Washer Repair 8 08-23-2010 02:13 PM
Kenmore 90 Series Washer Mr Lee Washer Repair 1 01-16-2010 04:04 PM
Kennmore 80 Series not agitating or spinning Bec Bec Washer Repair 1 12-31-2008 06:12 AM
Kenmore series 90 washer Glen Barclay Washer Repair 7 10-22-2008 12:53 PM
kenmore 70 series washer lafamiliallanes Washer Repair 1 05-17-2008 07:21 PM
