| » Washer spins slow or needs help to spin |
Model Number: RAB1121EW1 Brand: Roper Age: 5 - 10 years
Older washer needs replaced but need to keep it running a bit longer.
Just started not spinning fast enough, sometimes needs to be hand spun to get it going. What would cause this? Does the clutch need replaced? Would be grateful for any help. Thank you Ads By Google Related Models |
clutches possibly coated with oil from tower assembly or just worn out clutches. If you can hand start and it gets up to speed this would apply. If the unit will never get up to normal spin speed , a piece of clothing or other materieal may be between the inner and outer tub.
| Display Modes | |
| washer spins to slow | captainda | Washer Repair | 1 | 12-06-2009 07:22 AM |
| washer spins slow or doesn't spin | lordpuckx | Washer Repair | 4 | 11-30-2009 04:26 PM |
| hirlpool washer wont spin correctly(spins very slow) | jre72 | Washer Repair | 1 | 08-21-2009 06:08 AM |
| washer spins slow | kenfink | Washer Repair | 1 | 04-29-2009 05:43 PM |
| washer spins too slow | soggyclothes | Washer Repair | 1 | 02-10-2009 01:17 PM |
