| » Older GE Washer spills while filling! |
Model Number: WWA7050B Brand: GE Age: Less than 1 year
I haven't been able to figure out how to keep my older GE washer (wwa7050b) from spilling water while filling. It seems to have a weird blue device whose job it is to spill water on the floor -- see the attached image. The fill valve attaches to this device with a hose, and another hose runs from this device to the washer tub to fill it with water.
But this thing is open to the air, with a hole in the side of it where water overflows onto the ground while the things fills. At first I though, "Oh, ok. I guess this is the way they regulate the fill rate on this washer -- I guess I need to turn down the faucets that hook up to the fill valve until it stops leaking." But it never stops leaking, unless maybe I turn the water down to a tiiiiiiny trickle, which seems way too little water. Can anyone explain this thing to me? thank you! -dan |
Need a better picture, but this is a inlet assembly which acts as an aerator. I would just use silicone cement and close the hole. Before doing this, confirm there is no pinched hose to cause turbulence.
__________________
| Display Modes | |
| Whirlpool Gold Spills water | alma1031 | Washer Repair | 1 | 04-19-2008 09:07 PM |
| Washer Filling enough? | crgauth | Washer Repair | 2 | 01-29-2008 07:07 PM |
| Washer keeps filling but everything else works | rglaser | Washer Repair | 0 | 01-08-2008 06:30 AM |
| Older Kenmore washer appears "dead"! | Cappy | Washer Repair | 0 | 10-27-2007 08:18 PM |
| washer not filling | wannabe | Washer Repair | 7 | 08-28-2007 10:02 PM |
