Had a power failure. Not sure if it came from the washer because the problems with the washer happened after power failure but I have it plugged into a surge protector.
It continues to lock (hear it) then it makes that funny sound like it's trying to lock
- tried several times to reset by unplugging washer for lengthy periods of time
- checked all wire connections and cleaned them, nothing seemed unusual
- replaced door latch
- cleaned all around door area to insure a good seal
- I have to manually unlock it after all attempts
Now I don't know what else to do. I am wondering if I need to replace the door wire harness and if so, I need to know what part to order.
Any help would be great... thanks:confused:
