Discuss
Washer makes loud noise at end of spin cycle
 in
Washer Repair
My washer has started making a loud noise at the end of the spin cycle, what could be causing this?
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer makes loud noise at end of spin cycle
  #1 (permalink)
Old 02-23-2010, 08:08 PM
Junior Member
HVAC pirate is on a distinguished road
Unhappy Washer makes loud noise at end of spin cycle
Brand: Kenmore   Age: 1 - 5 years
  #2 (permalink)
Old 02-24-2010, 05:28 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Open it up and check out the suspension pads, support and the springs. You might try replacing the springs and pads, since they are not expensive, but if that does not cure things and the support parts are not damaged I would start to look at the brakes. Check Richappy' Sticky at the top of this page for what to do.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Agitates, won't spin.. makes loud belt noise.. every other cycle works fine. dolfan4764 Washer Repair 1 11-19-2011 09:30 AM
Makes loud bearing noise in spin cycle dwoutersz Washer Repair 2 07-15-2011 07:15 PM
GE Prodigy makes loud bearing noise on spin cycle TimN Washer Repair 0 02-02-2010 03:02 PM
Maytag Washer Makes Loud Moaning Noise During Spin Cycle DTOFT Washer Repair 1 06-11-2009 05:33 PM
Washer makes a loud clicking noise on spin cycle pattihanni Washer Repair 0 05-02-2009 09:40 AM
