| » Code F6 |
Model Number: GHW915OPW4 Brand: Whirlpool Age: 1 - 5 years
My Washer Doesn't Wash And The Code F6 Flashes Every Time
Your control board is not detecting any movement by the motor, so it shuts things down.
Open it up and check the wiring between the control unit and the motor control board. Unfortunately with this machine the problem can be in the motor, motor control board, wiring and even the door lock assembly. The MCU is the most likely culprit, but you will need to test if current is getting to it. If so, then it will likely need to be replaced.
__________________
| Display Modes | |
| code ld | dllee021 | Washer Repair | 3 | 04-10-2013 07:12 PM |
| F 1 code | sjb | Oven Repair (including Ranges and Cooktops) | 0 | 11-29-2009 03:35 PM |
| code pf | ej45 | Dishwasher Repair | 3 | 08-20-2009 12:23 PM |
| need code | asap24 | Dishwasher Repair | 1 | 04-21-2008 03:07 PM |
| need a code# | frankvalencia | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 04-21-2008 10:03 AM |
