Discuss
bearings and seal
 in
Washer Repair
The seal in the rear tub housing has failed and destroyed the bearings supporting the inner spin tub. Can I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » bearings and seal
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-17-2008, 08:49 AM
Adunc Adunc is offline
Junior Member
Adunc is on a distinguished road
Default bearings and seal
Model Number: fwt449gfs1   Brand: Frigidaire   Age: 5 - 10 years
The seal in the rear tub housing has failed and destroyed the bearings supporting the inner spin tub. Can I get just the seal and what is the best order for disassembly?
How do I calibrate the Dispenser-eccentric, it's set at -2 from the factory and it has NEVER worked for bleach(ruined clothes every time tried), nor softener.
Is there a service manual available?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Neptune bearings richappy Forum Announcements 7 07-16-2008 02:16 AM
bearings going bad? badbikers Washer Repair 3 05-17-2008 10:25 AM
Got The Maytag Neptune bearings out richappy Forum Announcements 0 04-30-2008 10:53 AM
Replacing Neptune bearings richappy Forum Announcements 0 04-29-2008 03:38 AM
bearings / seal replace gandra Washer Repair 2 11-03-2007 03:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
