Discuss
clothes wont wring out completely- still very wet!!
 in
Washer Repair
The whirlpool duet washer goes to F9 almost every cycle, and when I hit the cancel button, the washer does
Appliance Repair Forum > Appliance Repair Help > Washer Repair » clothes wont wring out completely- still very wet!!
  #1 (permalink)
Old 02-22-2010, 09:54 AM
Junior Member
rfenaroli is on a distinguished road
Default clothes wont wring out completely- still very wet!!
Model Number: GHW9100LQ1   Brand: Whirlpool   Age: 5 - 10 years
The whirlpool duet washer goes to F9 almost every cycle, and when I hit the cancel button, the washer does finish its cycle but the clothes stay very wet after spinning. Way too wet to put them in the dryer. The washer drain pump seems to work but is it possible that it just working poorly and shoud be replaced? or could this be a water level issue?
Thanks for any help!
Ads By Google
Related Models
Whirlpool GHW9100LQ1
Whirlpool GHW9100LQ2 Automatic Washer
Whirlpool GHW9100LW0
Whirlpool GHW9100LW1
Whirlpool GHW9100LW2 Automatic Washer
Whirlpool GHW9150PW0 Automatic Washer
Whirlpool GHW9150PW1 Automatic Washer
Whirlpool GHW9150PW2 Automatic Washer
Whirlpool GHW9150PW3 Automatic Washer
Whirlpool GHW9150PW4 Automatic Washer
Whirlpool GHW9160PW0 Automatic Washer
Whirlpool GHW9160PW1 Automatic Washer
Whirlpool GHW9160PW2 Automatic Washer
Whirlpool GHW9160PW3 Automatic Washer
Whirlpool GHW9160PW4 Automatic Washer
Whirlpool GHW9200LQ0
Whirlpool GHW9200LW0
Whirlpool GHW9250ML0 Automatic Washer
Whirlpool GHW9250ML1 Automatic Washer
Whirlpool GHW9250ML2 Automatic Washer
Whirlpool GHW9250MQ0 Automatic Washer
Whirlpool GHW9250MQ1 Automatic Washer
Whirlpool GHW9250MQ2 Automatic Washer
Whirlpool GHW9250MT0 Automatic Washer
Whirlpool GHW9250MT1 Automatic Washer
Whirlpool GHW9250MT2 Automatic Washer
Whirlpool GHW9250MW0 Automatic Washer
Whirlpool GHW9250MW1 Automatic Washer
Whirlpool GHW9250MW2 Automatic Washer
Whirlpool GHW9300PW0 Automatic Washer
Whirlpool GHW9300PW1 Automatic Washer
Whirlpool GHW9300PW2 Automatic Washer
Whirlpool GHW9300PW3 Automatic Washer
Whirlpool GHW9300PW4 Automatic Washer
Whirlpool GHW9400PL0 Automatic Washer
Whirlpool GHW9400PL1 Automatic Washer
Whirlpool GHW9400PL2 Automatic Washer
Whirlpool GHW9400PL3 Automatic Washer
Whirlpool GHW9400PL4 Automatic Washer
Whirlpool GHW9400PT0 Automatic Washer
Whirlpool GHW9400PT1 Automatic Washer
Whirlpool GHW9400PT2 Automatic Washer
Whirlpool GHW9400PT3 Automatic Washer
Whirlpool GHW9400PT4 Automatic Washer
Whirlpool GHW9400PW0 Automatic Washer
Whirlpool GHW9400PW1 Automatic Washer
Whirlpool GHW9400PW2 Automatic Washer
Whirlpool GHW9400PW3 Automatic Washer
Whirlpool GHW9400PW4 Automatic Washer
Whirlpool GHW9400SU0 Automatic Washer
Whirlpool GHW9460PL0 Automatic Washer
Whirlpool GHW9460PL1 Automatic Washer
Whirlpool GHW9460PL2 Automatic Washer
Whirlpool GHW9460PL3 Automatic Washer
Whirlpool GHW9460PL4 Automatic Washer
Whirlpool GHW9460PW0 Automatic Washer
Whirlpool GHW9460PW1 Automatic Washer
Whirlpool GHW9460PW2 Automatic Washer
Whirlpool GHW9460PW3 Automatic Washer
Whirlpool GHW9460PW4 Automatic Washer
Whirlpool GHWT160JXX0
Whirlpool GI1500PHB0
Whirlpool GI1500PHB3
Whirlpool GI1500PHB4 Ice Cube Maker
Whirlpool GI1500PHB5 Ice Cube Maker
Whirlpool GI1500PHB6 Ice Cube Maker
Whirlpool GI1500PHB7 Ice Cube Maker
Whirlpool GI1500PHB8 Ice Cube Maker
Whirlpool GI1500PHW0
Whirlpool GI1500PHW3
Whirlpool GI1500PHW4 Ice Cube Maker
Whirlpool GI1500PHW5 Ice Cube Maker
Whirlpool GI1500PHW6 Ice Cube Maker
Whirlpool GI1500PHW7 Ice Cube Maker
Whirlpool GI1500PHW8 Ice Cube Maker
Whirlpool GI1500XHB0
Whirlpool GI1500XHB1
Whirlpool GI1500XHB2
Whirlpool GI1500XHB3
Whirlpool GI1500XHB4 Ice Cube Maker
Whirlpool GI1500XHB5 Ice Cube Maker
Whirlpool GI1500XHB6 Ice Cube Maker
Whirlpool GI1500XHB7 Ice Cube Maker
Whirlpool GI1500XHB8 Ice Cube Maker
Whirlpool GI1500XHB9 Ice Cube Maker
Whirlpool GI1500XHN0
Whirlpool GI1500XHN1
Whirlpool GI1500XHN2
Whirlpool GI1500XHN3
Whirlpool GI1500XHN4 Ice Cube Maker
Whirlpool GI1500XHS0
Whirlpool GI1500XHS1
Whirlpool GI1500XHS2
Whirlpool GI1500XHS3
Whirlpool GI1500XHS4 Ice Cube Maker
Whirlpool GI1500XHS5 Ice Cube Maker
Whirlpool GI1500XHS6 Ice Cube Maker
Whirlpool GI1500XHS7 Ice Cube Maker
Whirlpool GI1500XHS8 Ice Cube Maker
Whirlpool GI1500XHS9 Ice Cube Maker
Whirlpool GI1500XHT1
Whirlpool GI1500XHT2
Whirlpool GI1500XHT3
Whirlpool GI1500XHT4 Ice Cube Maker
Whirlpool GI1500XHT5 Ice Cube Maker
Whirlpool GI1500XHT6 Ice Cube Maker
Whirlpool GI1500XHT7 Ice Cube Maker
Whirlpool GI1500XHT8 Ice Cube Maker
Whirlpool GI1500XHT9 Ice Cube Maker
Whirlpool GI1500XHW0
Whirlpool GI1500XHW1
Whirlpool GI1500XHW2
Whirlpool GI1500XHW3
Whirlpool GI1500XHW4 Ice Cube Maker
Whirlpool GI1500XHW5 Ice Cube Maker
Whirlpool GI1500XHW6 Ice Cube Maker
Whirlpool GI1500XHW7 Ice Cube Maker
Whirlpool GI1500XHW8 Ice Cube Maker
Whirlpool GI1500XHW9 Ice Cube Maker
Whirlpool GI15NDXTB0 Ice Cube Maker
  #2 (permalink)
Old 02-23-2010, 05:36 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Make sure the pump and the drain hoses are completely clean and free of any obstruction.
Then determine if the valves are open and water is coming into the machine during the cycle. Probably not, but if so you will probably want to replace the inlet valves.
If these check out, you need to check the wiring between the presssure switch and the control unit. Make sure it is complete and there is no break or short or fraying.
If it still does this, you have your choice of replacing the pressure switch or the control unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid dryer won't dry clothes completely timandjulie Dryer Repair 1 01-16-2010 11:00 AM
dryer wont dry clothes completely seb19591986 Washer Repair 1 04-28-2009 05:05 PM
Machine wont spin Clothes out completely Greenmyhs Washer Repair 2 04-07-2009 07:16 PM
GE Dryer not completely drying clothes Critter625 Dryer Repair 1 01-12-2009 07:34 AM
Whirlpool Dryer not completely drying clothes Cinner74 Dryer Repair 5 01-06-2009 09:07 AM
