| » Washer not filling |
Model Number: LSG7806AAE Brand: Maytag Age: 1 - 5 years
My stackable washer is not filling.
The pressure switch seems to be working (I hear 3 clicks while blowing into it). The machine is used and it was working. Is there a way to check the inlet valve before buying a new one? I already checked it for continuity and it has some through one side of the terminals only. Is that normal? Thanks in advance for the help. Kevin Ads By Google Related Models |
Unplug the machine and disconnect the connectors to the valve. Apply 120VAC to the terminals of each side of the valve and see if water flows from that side. If it does, suspect the timer. If not, replace the valve.
| Display Modes | |
| Washer over filling tub | NVMiner | Washer Repair | 1 | 09-03-2009 03:18 PM |
| washer keeps filling | ladonnalynn87 | Washer Repair | 1 | 01-20-2009 09:14 AM |
| washer not filling... | indyjones | Washer Repair | 1 | 09-01-2008 05:54 PM |
| washer not filling up | samali | Washer Repair | 3 | 08-28-2008 05:52 AM |
| washer not filling | wannabe | Washer Repair | 7 | 08-28-2007 09:02 PM |
