So i have the leaky door problem.What i found out was the washer is over filling on the water.whether its in the wash or rinse cycle and doesn't happen all the time,the water level gets about half up the door and the water starts pouring out.The bellow is not deisigned to hold back half a tub of water but designed to hold back splashing,and the water level is not supposed fill past the bottom height of the door opening, on all wash and rinse cycles.so my repair person has replaced the tube that runs from the tub up to control module and the control module that registers when tub full to stop flow.both times he came and replaced one part a time and worked great for aweek.Then the flood started.Any ways my question would be what other part that in line to recieve the signal to shut water off at the proper level could be bad i dont think its the bellow due to the discription i have been told it function is for.Has any one ran into this and had it successfully trouble shot and fixed.Im about ready to by a repair manual from whirlpool if they let me.I can't for see whirlpool being so closed minded about this problem.I have seen multiple complaints about leaking water from front door.When i emailed the company they said they havent heard of any problems like mine and they are sorry i am having so much trouble with the washer but to hirer a repair person.thanks for you time.
