Washer is mind numbing loud in spin cycle. Doesn't vibrate or shake though. Thanks for any help.
Unless a lot of history is not repeating itself, your rear seal has leaked and the water has destroyed your rear tub bearing. It is an expensive repair. There are some less exepnsive repair techniques and tools on the web, but my very strong recommendation is that you replace the machine. This is a very troubled unit and while there is a financial cost to a new or good used machine, you will be way better off without it.
Was afraid of bearing problem. Thanks much for the info.
