Discuss
Washer won't drain
 in
Washer Repair
I put a bathmat that gave off a lot of lint in my washer and it apparently clogged the drain/
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't drain
  #1 (permalink)
Old 05-14-2008, 08:34 PM
nsimone1056 nsimone1056 is offline
Junior Member
nsimone1056 is on a distinguished road
Default Washer won't drain
Brand: Roper   Age: 1 - 5 years
I put a bathmat that gave off a lot of lint in my washer and it apparently clogged the drain/filter. Is there any way to unclog it myself or do I need a repairman for this job?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-14-2008, 09:01 PM
Junior Member
Default
Sorry, it's a Roper Super capacity washer, model #RAS8244LQ1
  #3 (permalink)
Old 05-15-2008, 05:05 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
This is not too difficult job to do it yourself.
Remove the washer cabinet and the water pump. Remove the hoses from the water pump and clean them. The pump is better to replace.
Here are the complete instructions - How to remove the washer cabinet & the water pump.
- The part number for the water pump is AP2907492
Here are the break down diagrams for the Roper washer Model RAS8244LQ0
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 05-16-2008, 09:01 AM
Junior Member
Default
Thanks so much, I'll give it a try this weekend. I just couldn't figure out how to get the cabinet off. Once I do that, the repair should be simple.
  #5 (permalink)
Old 05-19-2008, 09:31 AM
Junior Member
Default
Gene,
followed your instructions (beautiful!) and was able to unclog the pump and get it back on. The washer is spinning and it drained without any clothes in it, but when I added a small load of wash I just can't get all the water to drain out. It almost seems like it's not spinning very hard/fast but it's hard to tell since I'm usually not watching it when this is going on!
Any other ideas?
Thx!
  #6 (permalink)
Old 05-21-2008, 01:31 PM
smsix smsix is offline
Junior Member
smsix is on a distinguished road
Default
my older model crosley washer will not aggitate and hums when it is suppose to be aggitating or draining is this the motor?
  #7 (permalink)
Old 05-22-2008, 06:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
nsimone1056,
Is it water inside or just wet clothes?
Did you check the pump impeller?
__________________
  #8 (permalink)
Old 05-22-2008, 06:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
smsix,
In order to provide most accurate advise we need the complete model number of the washer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't drain MMBell Washer Repair 4 07-28-2008 01:51 PM
Washer does not drain RobertB Washer Repair 6 03-31-2008 01:41 AM
washer will not drain kmoore77 Dishwasher Repair 2 12-21-2007 07:47 PM
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 02:41 PM
Washer won't drain jmcdonald62 Washer Repair 0 11-20-2007 08:19 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
