| » Washer fills with water when OFF |
Model Number: HE3T Brand: Kenmore Age: 5 - 10 years
Hey Folks, hoping you can help. I have a Kenmore HE3T front load washer that seems to work fine, EXCEPT that the tub fills with water between uses. It must be a slow leak, because I don't notice it unless we don't do laundry for a week or so. If it hasn't been used in a week, I see that the tub is full of water, but not high enough to leak out of the open door. Any thoughts on what I should do to fix this?
Thanks Tim Ads By Google Related Models |
Sounds like the water inlet valve is failing here is a video on checking it
service manuals |
So, I ordered the inlet valve and it showed up pretty quick. Replacing it was very simple. It also gave me a reason to clean out behind the washer/dryer and clear out the dryer vent. BTW - I did my 35' dryer vent with the "LintEater" and it worked very well. Another good tip from this site. Anyway, I haven't seen the issue again with the washer tub filling (yet). I'm assuming that the problem is fixed and I wanted to say thanks for the help.
Tim |
| Display Modes | |
| Washer fills with water when OFF | tballard | Washer Repair | 1 | 02-19-2010 06:33 PM |
| Washer fills with water and then nothing | mamabotanica | Washer Repair | 1 | 08-06-2009 09:32 AM |
| Washer fills with hot water after cycle done | jwallack | Washer Repair | 15 | 07-22-2009 07:55 PM |
| washer fills with water by itself | michele1234 | Washer Repair | 7 | 05-05-2009 09:08 AM |
| washer fills with water but does nothing after that | threads68 | Washer Repair | 0 | 06-06-2008 01:59 PM |
