Discuss
Kenmore HE3 elite F06 Error
 in
Washer Repair
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore HE3 elite F06 Error
  #1 (permalink)
Old 02-19-2010, 08:31 AM
Junior Member
pedroman74 is on a distinguished road
Default Kenmore HE3 elite F06 Error
Brand: Kenmore   Age: 1 - 5 years
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. Everything seems to check out except the drive motor. The tech sheet says normal reading is at 6 ohms. I have tested the resistance and it is about 0.5 - 0.6 between the three pins (1-2, 1-3, and 2-3). The tech sheet says infinity is abnormal but doesn't say what to do if the ohms are close to 0. Does this also mean the motor is bad?
Ads By Google
  #2 (permalink)
Old 02-20-2010, 06:20 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
The infinity reading would say that the windings have an open circuit. The zero reading could mean that they are fused together in some way.
Before you invest in a new motor, though, make sure your meter is set on the correct scale, and try to test the Ohms reading pn your meter on something you know for sure, like other parts of the washer in the tech notes.
Also, if you are testing through the MCU the problem can be in the MCU or the wiring to the motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite 2007 Dryer F2 Error fitzdp Dryer Repair 3 12-20-2009 06:46 AM
Kenmore Elite F30 Error code shreve66 Oven Repair (including Ranges and Cooktops) 0 11-24-2009 01:24 PM
Kenmore Elite Range error code help jayp Oven Repair (including Ranges and Cooktops) 15 07-08-2009 02:27 PM
Kenmore Elite Dryer E1 error message srtroy Dryer Repair 1 07-04-2009 06:40 AM
kenmore elite he3 -- F 05 error??? deannahoffmann Washer Repair 1 02-26-2009 05:46 AM
