Discuss
washer wont aggitate
 in
Washer Repair
I have a Whirlpool GVW9959KQ2 washer, it fills up with water but then won't switch to the next step.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer wont aggitate
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-29-2007, 11:35 AM
amcconnell amcconnell is offline
Junior Member
amcconnell is on a distinguished road
Default washer wont aggitate
Model Number: GVW9959KQ2   Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool GVW9959KQ2 washer, it fills up with water but then won't switch to the next step. Someone mentioned that it probably needs a mother board (also known as a motor control board). Is there any other reason this problem may occur other than what was listed in your troubleshooting guide? Is there a different part/controller that may need replacing instead of the entire board? If I change to rinse it won't fill up again, but will drain, so it may be stuck at aggitate.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-29-2007, 08:48 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi amcconnell
The answer on your question was posted here:
Top Load washer problem
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridgidaire Dryer wont heat Hozer Dryer Repair 8 09-11-2007 02:45 AM
oven wont ignite mick100 Oven Repair (including Ranges and Cooktops) 3 08-27-2007 09:10 AM
need advice tub wont spin out ton123 Washer Repair 1 08-15-2007 04:01 PM
dryer wont start phyllis Dryer Repair 4 07-28-2007 07:26 AM
Washing machine wont drain dirtyclothes Washer Repair 1 07-23-2007 06:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
