redsnook
#1 Posted : Tuesday, May 13, 2008 6:54:30 PM(UTC)
redsnook
Softener doesn't dispense. The screen on the washer says dispensing softener but it doesn't. It is filling up the bleach side again on the softener cycle. After the washing machine is done washing the softener is still their. Can anyone help me???
mdjson@gmail.com
#2 Posted : Thursday, May 15, 2008 6:26:22 AM(UTC)
mdjson@gmail.com
RS
I fixed my problem by cleaning out the sediment filters at the back of the washer and at the hose/facut connection. The fiters are delicate so be carful pulling them out. The cold water side is usually the worst.
I did not replace the solinoid as was suggested.
I do not use softener in my machine. The other possibility, as mentioned in Bosch FAQ, is the softener is to think and needs to be diluted.
redsnook
#3 Posted : Tuesday, May 20, 2008 6:18:58 PM(UTC)
redsnook
I took the hose off to clean the filter out. I replace the solenoids value also. The softner side still doesn't work. The bleach side is the only side that works. Can anyone help me???
redsnook
#4 Posted : Tuesday, May 20, 2008 6:29:40 PM(UTC)
redsnook
I replaced the control board with the lcd screen. Not the motor will not spin. It says it spinning but nothing happends. What is wrong now??? I am not even sure if the water softener problem is fix with. This thing is a pain in my butt. Someone please help me
