amtnlvr
#1 Posted : Wednesday, February 17, 2010 2:28:01 PM(UTC)
amtnlvr
Washer spin cycle not working, only works if I manually get tub spinning first. From looking at other posts it sounds like a bad clutch. Going to order clutch kit. Do I have to remove the spanner nut to get the shaft down through the bottom of tub to access the clutch? and if so do I need a special tool?
#2 Posted : Wednesday, February 17, 2010 4:57:50 PM(UTC)
Quote:
... Do I have to remove the spanner nut to get the shaft down through the bottom of tub to access the clutch? and if so do I need a special tool?...
Yes, you do have to remove the spanner nut and the inner tub. It's better to use a special spanner wrench.
You may want to check the drive block and th brakes as well.
You can find some useful information in our previous posts: http://forum.appliancepartspros...-washer-brake-shoes.html and
http://forum.appliancepartspros...ir/373-not-spinning.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSN1000KQ0 | AppliancePartsPros.com
whirlpool washer spin problem (Washer Repair)
by roadranger82 6/17/2017 11:13:55 AM(UTC)
Whirlpool Washer Spin problems (Washer Repair)
by aloulew 6/5/2012 2:25:12 PM(UTC)
whirlpool washer spin problems (Washer Repair)
by cuttincups 1/12/2011 9:20:10 AM(UTC)
Whirlpool Washer Spin Problem (Washer Repair)
by JDK0806 9/25/2009 1:15:24 PM(UTC)
Whirlpool washer spin problems (Washer Repair)
by diytoot 1/6/2009 12:38:13 PM(UTC)
by kimberly600 8/13/2008 5:47:30 AM(UTC)
