Discuss
metal ratteling while spinning
 in
Washer Repair
while washing clothes, there was a loud bang from washer. I opened lid, saw nothing, turned washer back on. Ever
Appliance Repair Forum > Appliance Repair Help > Washer Repair » metal ratteling while spinning
  #1 (permalink)
Old 05-12-2008, 04:46 PM
bebonz bebonz is offline
Junior Member
bebonz is on a distinguished road
Default metal ratteling while spinning
Model Number: LST 8244BQO   Brand: Whirlpool   Age: More than 10 years
while washing clothes, there was a loud bang from washer. I opened lid, saw nothing, turned washer back on. Ever since then, there is a metal ratteling when the washer spins. The basket is also easy to move back & forth. what could this be ?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-13-2008, 08:02 AM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Check your springs
Their should be 3 main springs on the bottom and one spring attached to the rear panel. driver brake cam.jpgthese springs attach around the base like the one pictured. You must remove the case to this washer to inspect the springs.
  #3 (permalink)
Old 05-13-2008, 08:06 AM
Senior Expert
APP Volunteer
Default removing the case
flip up the control panel and unplug the lid switch as pictureda lid-switch-unplug.jpgpop those S clips using a flat blade screw driver and tip the case forward. It will easily come right off and reveal the lovely operating parts of this easy to fix washer.
  #4 (permalink)
Old 05-13-2008, 12:42 PM
Junior Member
Default how to put washer back together
Thanks for your help. My brother attempted to "fix" my washer. He attempted to take the back panel off. He got all screws off, and some plastic pieces off. Now he does not know how to put the panel back on. Midway to the bottom of the panel is flopping around, and the bottom of washer is also loose. HELP !!!
  #5 (permalink)
Old 05-13-2008, 07:43 PM
Senior Expert
APP Volunteer
Default The rear panel install
This here washer is a modular design. The controls, water valve,down spout, water valve, hoses and drain pipe are all mounted on the rear wall. Everything you need to run a washer is mounted on that back wall except the tub motor and tranny. To put the back on simply make sure all of its components are back on the there and sit the back side on the base. Have the case sitting off to the side. Only 2 or 3 screws hold the back to the base. The case simply clips back onto the rear wall with the S clips. This washer is so simple to work on a caveman could do it. OOPz!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
middle arm not spinning jonesm776 Dishwasher Repair 0 03-25-2008 12:48 PM
Hinge on metal door is broken BAKERWG Oven Repair (including Ranges and Cooktops) 1 02-05-2008 07:49 AM
Washer not spinning mariner Washer Repair 5 01-26-2008 05:59 PM
not spinning peak_az@yahoo.com Washer Repair 4 01-19-2008 04:49 PM
how do I remove the metal cabnet and repace a new drum belt Tinas7 Dryer Repair 2 01-03-2008 05:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
