mike4784
#1 Posted : Monday, February 15, 2010 11:43:38 AM(UTC)
mike4784
Water over fills, Will drain on spin cycle
bugsquawsher
#2 Posted : Monday, February 15, 2010 12:04:08 PM(UTC)
bugsquawsher
Check you hose to your water level switch. Make sure it's clear. Then the next thing is to check you switch.
If you hook a hose up to it you should be able to blow on it and check the Contacts with a VOM to see if it switches. That doens't really mean it works right. you would need to determine what pressure is needed to detect a full load. The Switch is only 60 bucks.
Kitchen Aid Washer and GFCI issue (Washer Repair)
by M Yaworski 1/19/2019 5:14:20 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Kitchen aid washer sounds like ball bearings. Doesn't spin (Washer Repair)
by LMA 1/30/2016 8:40:53 AM(UTC)
Kitchen Aid washer has stopped working (Washer Repair)
by Punisher Bass 8/28/2015 3:18:59 PM(UTC)
kitchen aid washer wont run (Dishwasher Repair)
by gerry d 8/25/2014 8:08:36 AM(UTC)
Kitchen Aid Washer (Washer Repair)
by wildbirdie77 1/17/2014 5:52:39 AM(UTC)
Kitchen Aid Washer Hums, won't start (Washer Repair)
by carleton 12/9/2013 1:39:53 PM(UTC)
Kitchen Aid Washer will not spin (Dishwasher Repair)
by HiLife 12/12/2012 5:06:25 PM(UTC)
Kitchen Aid Washer won't spin (Washer Repair)
by silver1 2/12/2012 3:41:04 PM(UTC)
Kitchen aid washer wont spin (Washer Repair)
by D.Wick 1/6/2012 2:13:20 PM(UTC)
Kitchen Aid Washer - Repair or Replace??? (Washer Repair)
by schoolbusdriver9906 1/2/2012 12:45:49 PM(UTC)
by jwd03004 10/14/2011 11:15:47 AM(UTC)
kitchen aid washer not starting (Dishwasher Repair)
by paulclark 7/22/2011 6:06:20 AM(UTC)
capacity of kitchen aid washer (Washer Repair)
by bizymom 2/14/2011 6:56:16 PM(UTC)
kitchen Aid Washer Quiet Care Spin Cycle broke (Washer Repair)
by dandestef 2/7/2010 6:38:02 PM(UTC)
